Processing hotkey as action ?
llubse
Post by llubse »
I can define several hotkeys in one task.
If i have a task with two hotkeys, i.e. "A" and "B". Is it possible to program different actions depending on the pressed hotkey?
"A" pressed -> do action 1
"B" pressed -> do action 2
Why do you not want to have two different tasks with different hotkeys? IMHO, this is simpler and more clearly.
llubse
Post by llubse »
Oleg wrote:Why do you not want to have two different tasks with different hotkeys? IMHO, this is simpler and more clearly.
Because it is for one application. I gave an example for two hotkeys. But it will eventually be 6 of 7 hotkeys. For me it is more clearly if it is one task. Especially when you have to disable the task so you can't forget one.
If you attach a few hotkeys to the task, RoboTask can't determine, what hotkey has been pressed. Therefore you have to use the different tasks. But you can use a small trick.
Suppose we have a big task, but we want to do some different actions when we pressed different hotkeys ( or use the different triggers at all).
Create the main task with the following algorithm:
Do some general steps
if {TriggerFlag} = 1 then
   Actions for 1-st hotkey
end if
if {TriggerFlag} = 2 then
   Actions for 2-nd hotkey
end if
Remove variable TriggerFlag
We use the TriggerFlag variable in order to tell to task what trigger has been fired.
Next, we have to create a few auxiliary tasks with different hotkeys or triggers like this:
Set variable TriggerFlag to 1 // 2 - for second trigger, 3 - for third, and so on.
Start task "Main task"
