sql query result to Excel
Stranger
Post by Stranger »
I have a problem, maybe anyone could help me. I need to put query results to excell file. Sql query works fine - I put it in Dataset loop, but how to put thes date to Excel, I don't know.
Thanks.
Just see this example. This task does a database loop and puts each fields of query into corresponding cell of Excell.
How to use :
1. Open excell document
2. Select necessary cell
3. Press Ctrl-Alt-[ for executing the task.
Don't forget to enable the task after importing. Also, you can assign another hot key to the task.
