How to make a division?
Alejandro
Post by Alejandro »
I made a task to determinate the total HDD usage, but it gives me bytes, I want to convert it to gb's... where may I make a division of a value??? in this case {TOTAL_SIZE}/1073741824I searched the forum and the online help without success...
There is Evaluate action for this purpose. This is in additional BASIC plugin. Just download here and install it.
BASIC plugin contain two actions:
Evaluate - for evaluating any mathematic expressions
BASIC script - for writing small subprograms on BASIC language
Alejandro
Post by Alejandro »
The more I use this thing the more I love it :)I'll try it. Thank you...
Alejandro
Post by Alejandro »
It worked... but I get the "error in expression" messsage... I tried several ways until I realized that i'ts because the size of the numbers... is the disk space in bytes (about 40,000,000,000) if I reduce the number to 400,000,000 (nine digits) it works...I can show numbers bigger than 9 digits, but I can't make operations with them (in this case a division) is this normal??? Is there a way to fix it???Thank you...
Try to use the expression {TOTAL_SIZE}#/1073741824
Symbol '#' says to BASIC that {TOTAL_SIZE} is a double value (a floating point )not an integer. DOUBLE have more large range of values. By default Basic think that {TOTAL_SIZE} is an integer value. This is small trick to avoid an error.
Also you may write so: {TOTAL_SIZE}.0/1073741824
Alejandro
Post by Alejandro »
duh :)Now working fine.Thank you...!
