Get value from JSON
Get value from JSON
I'm struggling a bit with getting a value from a JSON string.
{"jobStatus":{"jobId":"69fca4afa1630f5937153bff","created":1778164911572,"language":"nl","status":"OPEN","nrAudioSeconds":23,"transcriptionType":"transcription","filename":"xxx.ext","jobType":"direct","jobOptions":{"burnInSubtitles":false,"anonymization":"NONE","portal":true,"timestampEnabledInExport":true,"dresingPehl":false,"extendedDelivery":"NONE"}}}
I need just the JobId. I've played around with loops, XML Node, but I can't get it working. What is your best method, Oleg?
Re: Get value from JSON
Use the expression: {json:_string.jobStatus.jobId}
where _string is the variable name
Please note that JSON is case sensitive
Look at my example below:
CatID=INTEGER|307868550
ExternalName=STRING|"Task1583"
ID=INTEGER|928583325
Name=STRING|"Parse JSON"
StepPause=INTEGER|0
Name=STRING|"Set variable ""_string"" with value ""{""jobStatus"":{""jobId"":""69fca4afa1630f5937153bff"",""created"":1778164911572,""language"":""nl"",""status"":""OPEN"",""nrAudioSeconds"":23,""transcriptionType"":""transcription""..."""
_rt_variables_produced=STRING|"_string"
varname=STRING|"_string"
varvalue=STRING|"{""jobStatus"":{""jobId"":""69fca4afa1630f5937153bff"",""created"":1778164911572,""language"":""nl"",""status"":""OPEN"",""nrAudioSeconds"":23,""transcriptionType"":""transcription"",""filename"":""xxx.ext"",""jobType"":""direct"",""jobOptions"":{""burnInSubtitles"":false,""anonymization"":""NONE"",""portal"":true,""timestampEnabledInExport"":true,""dresingPehl"":false,""extendedDelivery"":""NONE""}}}"
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"source string: {_string}"
line00000001=STRING|"***********"
line00000002=STRING|"Job ID: {json:_string.jobStatus.jobId}"
line00000003=STRING|"Created: {json:_string.jobStatus.created}"
line00000004=STRING|"Language: {json:_string.jobStatus.language}"
line00000005=STRING|"Status: {json:_string.jobStatus.status}"
line00000006=STRING|"Audio Seconds:  {json:_string.jobStatus.nrAudioSeconds}"
line00000007=STRING|"File Name:  {json:_string.jobStatus.filename}"
linecount=STRING|"8"
timeout=STRING|"10"
Also read this topic: viewtopic.php?p=12298
You are the best. As usual. Thanks!
