Password Variable Not Working in “Pack Files” Action
kentledgetrembling
Post by kentledgetrembling »
Hi everyone,
I’m new here and I’ve run into a strange issue with the “Pack Files” action. When I try to use a password stored in a variable, Robotask uses the variable name itself as the password instead of the actual value inside the variable.
Example:
Variable name: {PSWD_LOC}
Variable value: MyPassword
Password applied during packing: {PSWD_LOC} instead of MyPassword
I’ve tried different formats (with/without braces, local/global variables, etc.) but nothing seems to change the behavior. I’m not sure if this is a bug or if I’m missing something.
Has anyone else experienced this or found a workaround?
Thanks!
Re: Password Variable Not Working in “Pack Files” Action
It works. Test my example
CatID=INTEGER|307868550
ExternalName=STRING|"Task1620"
ID=INTEGER|1182452978
Name=STRING|"[test psw var] Zip Selected File"
StepPause=INTEGER|0
Name=STRING|"Open Dialog"
caption=STRING|"Open File to Zip"
default=STRING|"None"
folder=STRING|"C:\"
variable=STRING|"FILETOZIP"
Name=STRING|"Set variable ""_psw"" with value ""MyPassword"""
_rt_variables_produced=STRING|"_psw"
varname=STRING|"_psw"
varvalue=STRING|"MyPassword"
operator=STRING|"1"
value1=STRING|"FILETOZIP"
value2=STRING|"None"
Name=STRING|"Show ""file {FILETOZIP}"""
msg0=STRING|"file {FILETOZIP}"
msg1=STRING|"ZIP file {FILETOZIP}.zip"
msgcount=STRING|"2"
ActionID=STRING|"A_ZIP_PACK"
Name=STRING|"Pack Files"
action=STRING|"0"
coment0=STRING|"{DateTime}, {DayOfWeek}"
coment1=STRING|"This zip-archive created by RoboTask"
comentcount=STRING|"2"
compreslevel=STRING|"1"
destfile=STRING|"{FILETOZIP}.zip"
file0=STRING|"{FILETOZIP}"
includeemptydirs=STRING|"0"
includesubfolders=STRING|"1"
incsysandhidden=STRING|"0"
junkdirnames=STRING|"0"
password=STRING|"4383941112429244395841112"
split=STRING|"0"
unit=STRING|"0"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""You clicked Cancel"""
msg0=STRING|"You clicked Cancel"
Save the task text to a file and use the Task->Import menu to import the task into RoboTask.
