Log copied files - Use as boolean / checklist
Hey Oleg,
Quite a long story why I need this, but I need to have some kind of log file in which file-paths are being written. (I have that already), now...if a file is going to be copied AND he is already in that logfile (= copied 1 time), he should skip it. What is your best practice?
Shall I play with text loops, or..?
Re: Log copied files - Use as boolean / checklist
You can add the file name to the end of your log in any case (Write Text File
and then sort the text, removing duplicates (see Sort Text action).
That's not what I meant, or do we have a misunderstanding? ;)
Task: copy files, search in folder for *.*
File 1 found --> Check logfile
Is filepath 1 found in logfile? NO COPY, go to file 2
Is filepath 1 not found in logfile? DO COPY file 1 and add to logfile.
The old task which I've found (Search substring in text files (imported)) doesn't fullfill this. It should look in 1 textfile for a filename, not every time a {filename}.txt.
Perhaps I misunderstood you...
Do you want to avoid copying a file if it already exists in the log?
It would be better to create a table in the database. In this case, you can easily check whether a record exists in the table.
In the case of a text file, you need to use Text Loop and scan the whole file. For example, like this (see example below)
CatID=INTEGER|1133661666
ExternalName=STRING|"Task85"
ID=INTEGER|17024800
Name=STRING|"Check exitence in the log"
StepPause=INTEGER|0
Action14=FOLDER
Name=STRING|"Set variable ""_LogFile"" with value ""C:\temp\List.txt"""
_rt_variables_produced=STRING|"_LogFile"
varname=STRING|"_LogFile"
varvalue=STRING|"C:\temp\List.txt"
value1=STRING|"{_Found}"
Name=STRING|"Log message (neutral) ""File exists in the log"""
expression=STRING|"3"
message=STRING|"File exists in the log"
mode=STRING|"0"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Log message (warning) ""File does not exist in the log"""
[Actions\Action13\Params]
message=STRING|"File does not exist in the log"
mode=STRING|"0"
type=STRING|"1"
[Actions\Action14]
Name=STRING|"Set variable ""_FileName"" with value ""example.xlsx"""
_rt_variables_produced=STRING|"_FileName"
varname=STRING|"_FileName"
varvalue=STRING|"example.xlsx"
Name=STRING|"Set variable ""_Found"" with value ""FALSE"""
_rt_variables_produced=STRING|"_Found"
varname=STRING|"_Found"
varvalue=STRING|"FALSE"
Name=STRING|"Text Loop"
_rt_variables_produced=STRING|"_line"
delimiter_no=STRING|"0"
destvar=STRING|"_line"
file=STRING|"{_LogFile}"
linecount=STRING|"0"
quote_char=STRING|"0"
sourcetext=STRING|"0"
strict_delim=STRING|"1"
value1=STRING|"{_FileName}"
value2=STRING|"{_line}"
Name=STRING|"Set variable ""_Found"" with value ""TRUE"""
varvalue=STRING|"TRUE"
Name=STRING|"Break"
Yupz, this works as it should, thanks!
