Looking for a way to type the text in the clipboard
OldGeek
Post by OldGeek »
Some web pages and some windows apps either block pasting from the clipboard using [Ctrl] + V. I need a way to type the text from the clipboard
Thanks in advance for any help
Happy Holidays
Re: Looking for a way to type the text in the clipboard
Try Send Keystrokes with expression {ClipBoardContent}
Also you can put clipboard content into your own variable: Get Text from Clipboard
Another way:
Use Web automation actions
Look at Web Automation Send keys
OldGeek
Post by OldGeek »
Thank You. I was looking in the 'clipboard' and 'String' categories. I'll give the Send Keystrokes
