{FolderTime({SomeFolder})}
OldGeek
Post by OldGeek »
I can't seem to get this system variable to return anything.
Re: {FolderTime({SomeFolder})}
What folder name contains variable SomeFolder?
It seems it contains incorrect folder name or variable doesn't exist
Look at the example below. It works
CatID=INTEGER|1133661666
ExternalName=STRING|"Task93"
ID=INTEGER|581230995
Name=STRING|"Folder times"
StepPause=INTEGER|0
Name=STRING|"Set variable ""SomeFolder"" with value ""C:\Users"""
_rt_variables_produced=STRING|"SomeFolder"
varname=STRING|"SomeFolder"
varvalue=STRING|"C:\Users"
Name=STRING|"Show ""1 - {FolderTime({TempDir})}"""
msg0=STRING|"1 - {FolderTime({TempDir})}"
msg1=STRING|"2 - {FolderTime(c:\program files)}"
msg2=STRING|"3 - {FolderTime(c:\temp)}"
msg3=STRING|"4 (incorrect)- {FolderTime({NoVar})}"
msg4=STRING|"5 (incorrect)- {FolderTime(c:\incorrect folder)}"
msg5=STRING|"6 ({SomeFolder})- {FolderTime({SomeFolder})}"
msgcount=STRING|"6"
OldGeek
Post by OldGeek »
The example I was trying to make was "SomeFolder" was a variable. But anyway thanks for your example. I found my error.
