Parsing data from email subject
Giup
Post by Giup »
Hello.
I would need some help to create a task with the following steps:
1. Read new email from a POP account;
2. Read value1 and value2 from email subject: values are separated by a comma;
3. Copy the values in column A and B of an excel spreadsheet with a fixed name;
4. Appending new values under the old ones, every time a task is initiated by a new email.
Thanks,
Giuseppe
Re: Parsing data from email subject
Use Email actions: POP3 Open, enumerate emails in mail box POP3 Mail Loop, POP3 Download Email
maybe you need delete downloaded email - POP3 Delete Email
You can convert string to standard comma-separated string and then you can read elements like this: {MySubj(0)}, {MySubj(1)} and etc.
Use Excel actions for this
You need to find an empty cell in specified column.
To read cells use Excel Get Cells
To write cell use Excel Set Cells
Do not forget to save EXCEL document at the end of task. Any changes will not be saved automatically.
Giup
Post by Giup »
Hello.
I'm stuck here and not able to find the first free row...
CatID=INTEGER|0
ExternalName=STRING|"Task1"
ID=INTEGER|-1049195316
Name=STRING|"POP3 Open..."
StepPause=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
ActionID=STRING|"A_EMAIL_OPEN"
Name=STRING|"POP3 Open"
host=STRING|"mailgal.gallozzi.com"
oauthmode=STRING|"0"
password=STRING|"33896434534423247062286132855615756"
port=STRING|"110"
SSL=STRING|"0"
SSL2=STRING|"0"
SSL3=STRING|"0"
TLS10=STRING|"1"
TLS11=STRING|"1"
TLS12=STRING|"1"
user=STRING|"test.gg@mailgal.gallozzi.com"
Name=STRING|"Set variable ""count_row_number"" with value ""{row_nr}+1"""
_rt_variables_produced=STRING|"count_row_number"
varname=STRING|"count_row_number"
varvalue=STRING|"{row_nr}+1"
ActionID=STRING|"A_LOOPARRAYELEMENTS"
Name=STRING|"Loop on comma-separated string"
[Actions\Action13\Params]
_rt_variables_produced=STRING|"CurrentArrayElement"
delimiter=STRING|"0"
mode=STRING|"0"
quotechar=STRING|"0"
source=STRING|"{MySubj}"
strictdelimiter=STRING|"1"
variable=STRING|"CurrentArrayElement"
[Actions\Action14]
ActionID=STRING|"A_EXCEL_SET"
Name=STRING|"Excel Set Cells"
[Actions\Action14\Params]
cell00000000=STRING|"A{count_row_number}"
cell00000001=STRING|"B{count_row_number}"
count=STRING|"2"
setmode=STRING|"0"
var00000000=STRING|"{MySubj(0)}"
var00000001=STRING|"{MySubj(1)} "
worksheet=STRING|"1"
[Actions\Action15]
[Actions\Action16]
ActionID=STRING|"A_EXCEL_SAVEDOC"
Name=STRING|"Excel Save Document"
[Actions\Action17]
ActionID=STRING|"A_EXCEL_CLOSE"
Name=STRING|"Excel Close"
[Actions\Action18]
ActionID=STRING|"A_EMAIL_LOOP"
Name=STRING|"POP3 Mail Loop"
_rt_variables_produced=STRING|"1,subject"
breakafter=STRING|"0"
limit=STRING|"100"
number=STRING|"1"
reverse=STRING|"0"
subj=STRING|"subject"
usecc=STRING|"0"
usedate=STRING|"0"
usefrom=STRING|"0"
usepriority=STRING|"0"
usesize=STRING|"0"
usesubj=STRING|"1"
useto=STRING|"0"
ActionID=STRING|"E_EMAIL_DOWNLOAD"
Name=STRING|"POP3 Download Message"
extract=STRING|"0"
num=STRING|"1"
overwrite=STRING|"0"
savefilenames=STRING|"0"
savetofile=STRING|"{TempDir}\{Year}{MonthNo}{Day}{Hours}{Minutes}{Seconds}{mSeconds}.eml"
Name=STRING|"Split Text"
_rt_variables_produced=STRING|"MySubj"
colon=STRING|"0"
comma=STRING|"1"
other=STRING|"0"
otherchar=STRING|" "
quote=STRING|"2"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"1"
string=STRING|"{subject}"
tab=STRING|"0"
variable=STRING|"MySubj"
filename=STRING|"C:\Users\Giuseppe Lamberti\Desktop\lista_dogane.xlsx"
hide=STRING|"0"
mode=STRING|"0"
tryconnect=STRING|"0"
Name=STRING|"Set variable ""row_nr"" with value ""1"""
_rt_variables_produced=STRING|"row_nr"
varname=STRING|"row_nr"
varvalue=STRING|"1"
Name=STRING|"While loop"
operator=STRING|"4"
type=STRING|"1"
value1=STRING|"{row_nr}"
value2=STRING|"100"
ActionID=STRING|"A_EXCEL_GET"
Name=STRING|"Excel Get Cells"
_rt_variables_produced=STRING|"valA,valB"
cell00000000=STRING|"A{row_nr}"
cell00000001=STRING|"B{row_nr}"
count=STRING|"2"
var00000000=STRING|"valA"
var00000001=STRING|"valB"
operator=STRING|"8"
value1=STRING|"{valA} And {valB}"
value2=STRING|""""""
Look at my example below
CatID=INTEGER|1133661666
ExternalName=STRING|"Task87"
ID=INTEGER|-1448138562
Name=STRING|"How to find an empty row"
StepPause=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Set variable ""_excelDoc"" with value ""C:\temp\example.xlsx"""
_rt_variables_produced=STRING|"_excelDoc"
varname=STRING|"_excelDoc"
varvalue=STRING|"C:\temp\example.xlsx"
count=STRING|"2"
setmode=STRING|"0"
var00000000=STRING|"{_mySubj(0)}"
var00000001=STRING|"{_mySubj(1)}"
Name=STRING|"Break"
[Actions\Action14]
[Actions\Action15]
Name=STRING|"Set variable ""_mySubj"" with value ""ColA_{RandomValue(1000)},ColB_{RandomValue(1000)}"""
_rt_variables_produced=STRING|"_mySubj"
varname=STRING|"_mySubj"
varvalue=STRING|"ColA_{RandomValue(1000)},ColB_{RandomValue(1000)}"
filename=STRING|"{_excelDoc}"
hide=STRING|"0"
mode=STRING|"0"
varvalue=STRING|"1"
operator=STRING|"4"
type=STRING|"1"
value2=STRING|"100"
count=STRING|"2"
case#1=STRING|"0"
count=STRING|"2"
operator=STRING|"8"
operator#1=STRING|"8"
type#1=STRING|"0"
value1=STRING|"{valA}"
value1#1=STRING|"{valB}"
Name=STRING|"Increment variable ""row_nr"""
incement=STRING|"1"
vaiable=STRING|"row_nr"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
