SFTP - No path in filename
Hey Oleg,
Although I have declared the full path, I see (at least, from error-perspective) it seems he ignores the folder. What am I doing wrong here?
Re: SFTP - No path in filename
I need your task to say something...
I tested similar example, it works without problem.
Remove login parameters and send your task to me to oleg@robotask.com
