Log Message Actions not working
OldGeek
Post by OldGeek »
Normally these have worked. I always set Log Level to Errors Only after I have debugged my task. But now if I make a small change such as
adding a [If - End If] action with new Log Message actions the Log Message actions don't appear in the .LOG file.
-: 11/13/2025 3:55:00 PM: ====== [Start Task:] Backup Tasks Daily
-: 11/13/2025 3:55:01 PM: [STEP: 17] Copy: C:\Users\redwa\Documents\RoboTask\*.* -> C:\Users\redwa\Documents\RoboTask Backup\Thursday
-: 11/13/2025 3:55:15 PM: ====== [End Task:] Backup Tasks Daily
-: 11/14/2025 3:55:00 PM: ====== [Start Task:] Backup Tasks Daily
-: 11/14/2025 3:55:12 PM: ====== [End Task:] Backup Tasks Daily
BTW: How do I attach a .tsk file
CatID=INTEGER|1332952927
ContinueOnError=INTEGER|2
ExternalName=STRING|"Task56"
ID=INTEGER|-83262569
Name=STRING|"Delete Empty Log Files"
StepPause=INTEGER|0
ToLog=INTEGER|1
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
ActionID=STRING|"A_CLEAR_TASKLOG"
Name=STRING|"Clear Task Log"
Name=STRING|"Set variable ""CurrentFileSize"" with value ""{FileSize({CurrentLog})}"""
_rt_variables_produced=STRING|"CurrentFileSize"
varname=STRING|"CurrentFileSize"
varvalue=STRING|"{FileSize({CurrentLog})}"
Enabled=INTEGER|0
expression=STRING|"3"
message=STRING|"[STEP: 11] Current Log File: {CurrentLog} | Size: {CurrentFileSize}"
mode=STRING|"0"
[Actions\Action12\Params]
operator=STRING|"4"
type=STRING|"1"
value1=STRING|"{CurrentFileSize}"
value2=STRING|"3"
[Actions\Action13\Params]
message=STRING|"[STEP: 13] Deleting Log File: {CurrentLog} | Size: {CurrentFileSize}"
mode=STRING|"0"
[Actions\Action14]
Name=STRING|"Delete File"
[Actions\Action14\Params]
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{CurrentLog}"
hidden=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
ToRecycleBin=STRING|"0"
[Actions\Action15]
Name=STRING|"Increment variable ""DeleteCount"""
[Actions\Action15\Params]
incement=STRING|"1"
vaiable=STRING|"DeleteCount"
[Actions\Action16]
[Actions\Action17]
[Actions\Action18]
[Actions\Action18\Params]
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{DeleteCount}"
value2=STRING|"0"
[Actions\Action19]
Name=STRING|"Log message (information) ""[STEP: 18] Deletied {DeleteCou..."""
[Actions\Action19\Params]
message=STRING|"[STEP: 18] Deletied {DeleteCount} Log Files "
mode=STRING|"0"
message=STRING|"====== [Start Task:] Delete Empty Log Files"
mode=STRING|"0"
[Actions\Action20]
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action21]
Name=STRING|"Log message (information) ""[STEP: 21] Deleted Zero Log Fi..."""
[Actions\Action21\Params]
message=STRING|"[STEP: 21] Deleted Zero Log Files"
mode=STRING|"0"
[Actions\Action22]
[Actions\Action23]
[Actions\Action23\Params]
Count=STRING|"1"
file0=STRING|"{LogFilesList}"
hidden=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
ToRecycleBin=STRING|"1"
[Actions\Action24]
Name=STRING|"Log message (information) ""[STEP: 24] Deleted: {DeleteCou..."""
[Actions\Action24\Params]
message=STRING|"[STEP: 24] Deleted: {DeleteCount} File(s)"
mode=STRING|"0"
[Actions\Action25]
[Actions\Action25\Params]
message=STRING|"====== [End Task:] Delete Empty Log Files"
mode=STRING|"0"
Name=STRING|"Set Current Folder ({LogFolder})"
folder=STRING|"{LogFolder}"
Name=STRING|"Create local variable ""LogFilesList"" with value ""LogFiles.txt"""
_rt_variables_produced=STRING|"LogFilesList"
varname=STRING|"LogFilesList"
varvalue=STRING|"LogFiles.txt"
Name=STRING|"Create local variable ""CurrentLog"" with value """""
_rt_variables_produced=STRING|"CurrentLog"
linecount=STRING|"0"
varname=STRING|"CurrentLog"
Name=STRING|"Create local variable ""CurrentFileSize"" with value ""0"""
varvalue=STRING|"0"
Name=STRING|"Create local variable ""DeleteCount"" with value ""0"""
_rt_variables_produced=STRING|"DeleteCount"
varname=STRING|"DeleteCount"
varvalue=STRING|"0"
Name=STRING|"Create File List (file: {LogFilesList})"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
date1=STRING|"20240625"
date2=STRING|"20240625"
destfile=STRING|"{LogFilesList}"
DuringMinutes=STRING|"1"
file0=STRING|"*.log"
savetofile=STRING|"1"
savetovar=STRING|"0"
searchkind=STRING|"0"
sort=STRING|"1"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
Name=STRING|"Text Loop"
delimiter_no=STRING|"0"
destvar=STRING|"CurrentLog"
quote_char=STRING|"0"
sourcetext=STRING|"0"
strict_delim=STRING|"1"
Name=STRING|"Scheduler (Every Saturday @ 3:40pm)"
UniqueID=INTEGER|691018658
periodicity=STRING|"1"
periodparameter=STRING|"0000001"
periodparameter2=STRING|"11111"
startdate=STRING|"45753"
time0=STRING|"56400000"
timecount=STRING|"1"
wakeup=STRING|"0"
Re: Log Message Actions not working
put the task text beween CODE marks
use this button to put marks into you post text and paste the task text between marks
Put [code] marks
Put [code] marks
You also can write these marks manually:
[code]Put the task text here[/code]
This will have the same effect.
You may have already deleted empty logs during debugging.
Look at the step #19 and #21
If you set log lever to Errors Only then you will not see these messages. Set log type to Neutral
By the way: version 10.6 already has a task debugger.
You can set breakpoints, view all local and global variables and perform the task in step-by-step mode.
OldGeek
Post by OldGeek »
WOW a debugger, that is great news. I'll download and install the newest version.
As always Thank You for all your quick help responses.
