RoboTask 10.6 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 10.6 now
What's new in RoboTask 10.6:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
RoboTask 10.6
+ Added Task debugger. Launched from the task editor. Allows you to execute a task step by step with control over local and global variables.
+ Added action "Enter date and time" to dialogs group
+ The fields 'Date picker', 'Time picker' and 'DateTimePicker' have been added to the "Custom Dialog" action.
+ The initial value has been added to the "Input Box" action.
+ New system variable {IsVariableDefined(MyVarName)}.
+ Added logging of user information (not just the client's IP address) when a network client connects. Information about failed attempts is also logged.
+ 'Power' and 'Energy groups' have been added to the "Value Converter" action.
* Fixed the "Exit RoboTask" action for service mode
* Some issues with character encoding in the Multibyte Character Set system have been resolved.
- Fixed an issue with assigning values to RoboTask user variables in "Python Script" and "JavaScript/Node.js Script" actions.
* The algorithm has been improved in the "CSV data loop" action. If the source data is empty, no error is generated. Only a warning is issued.
* The RoboTask installation process algorithm has been improved. This has been accelerated several times over.
* The JSON prefix is now optional. If the format of the variable field reference matches the JSON format, JSON processing is implied.
* Improved the "Log dialog" action algorithm. When an error occurs, the task is not interrupted, but a warning is generated and the message is logged in the task log.
* Many other small optimizations, improvements and bug fixes.
Locked
