Rename Folder
OldGeek
Rename Folder
Post by OldGeek »
I recently had the need to rename a folder and because I've received so much help here I thought I would share my solution.
CatID=INTEGER|661131612
ExternalName=STRING|"Task19"
ID=INTEGER|1541574132
Name=STRING|"ReName Folder"
StepPause=INTEGER|0
Name=STRING|"VB Script"
expandvars=STRING|"0"
line00000000=STRING|"Sub RenameFolder(OrgPath,NewPath)"
line00000002=STRING|"  Set FS = CreateObject(""Scripting.FileSystemObject"")"
line00000003=STRING|"  If FS.FolderExists(OrgPath) Then"
line00000004=STRING|"    LogMessage(""Renaming folder "" + orgPath + "" -> "" + NewPath)"
line00000005=STRING|"    FS.MoveFolder OrgPath, NewPath"
line00000006=STRING|"  Else"
line00000007=STRING|"    LogMessage(""The folder "" + OrgPath + "" does not exist"")"
line00000008=STRING|"  End If"
line00000009=STRING|"End Sub"
line0000000B=STRING|"Path1 = ""C:\Users\redwa\Documents\RoboTask\TaskBackup"""
line0000000C=STRING|"Path2 = ""C:\Users\redwa\Documents\RoboTask\DeleteMe"""
line0000000E=STRING|"LogMessage(""Original Folder Name: "" + Path1)"
line0000000F=STRING|"LogMessage(""New Folder Name: "" + Path2)"
line00000010=STRING|"RenameFolder Path1,Path2"
linecount=STRING|"17"
savescript=STRING|"0"
Re: Rename Folder
What don't you like the "Rename Folder" action?
OldGeek
Re: Rename Folder
Post by OldGeek »
I guess I just didn't see it. You can delete this post
Re: Rename Folder
Let it remain as an example of using VB Script.
