[TYPE] Logging Advanced Tab
OldGeek
Post by OldGeek »
On your Help File [https://robotask.com/help/index.html?TaskEdit_2.htm] it shows "You can set options for logging on the Advanced tab" but to make it clearer I think it should say "Settings Tab"
In addition it shows "Add Task" where it should be "New Task" and one more ...
That same help page shows "dialog box" for the add and edit. I think it should be "New Task Window" and "Edit Task Window"
