How to trigger a Robotask action only when a specific USB device is connected?
Rosebl
Post by Rosebl »
Hi everyone,
I’m trying to create a task in Robotask that runs automatically only when a specific USB drive (identified by its volume label or serial number) is connected to my PC. I want the task to back up some files to that drive, but it shouldn’t start if any other USB device is plugged in.
I’ve tried using the “Device Connected” trigger, but it seems to react to any USB device. Is there a way to filter the trigger by a specific drive label or hardware ID within Robotask, or do I need to add a conditional check in the task itself?
Has anyone successfully set up something like this?
Rose Black Retro Bowl
Re: How to trigger a Robotask action only when a specific USB device is connected?
Yes, trigger reacts to any USB drive.
But you can read volume label in the task. See {VolumeLabel(c:\)} system variable
Then you use If..Then actions to analyze it
also take a look at this example
CatID=INTEGER|281496679
ExternalName=STRING|"Task1502"
ID=INTEGER|-658729983
Name=STRING|"Write to USB device (on devivce change)"
StepPause=INTEGER|0
Name=STRING|"Create local variable ""DISK"" with value ""I:"""
_rt_variables_produced=STRING|"DISK"
varname=STRING|"DISK"
varvalue=STRING|"I:"
value1=STRING|"{VolumeLabel({disk}\)}"
value2=STRING|"transfer"
ActionID=STRING|"A_FOLDER_SYNCHRONIZE"
Name=STRING|"Synchronize Folders (test)"
checkfile=STRING|"1"
clearro=STRING|"1"
details=STRING|"1"
detailstovar=STRING|"0"
exact=STRING|"0"
foder1=STRING|"D:\test"
foder2=STRING|"{disk}\test"
hidden=STRING|"0"
howsync=STRING|"0"
includeempty=STRING|"0"
includemask=STRING|"*.*"
maxtimeout=STRING|"15"
subdir=STRING|"1"
system=STRING|"0"
twosecprecision=STRING|"1"
colorscheme=STRING|"0"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"Synchronisation comlete!!!"
position=STRING|"3"
title=STRING|"Sync comlete"
width=STRING|"330"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Log message (error) ""Wrong drive!!!"""
expression=STRING|"3"
message=STRING|"Wrong drive!!!"
mode=STRING|"0"
type=STRING|"2"
EventID=STRING|"E_SYSEVENTS_DEVICECHANGE"
Name=STRING|"On Device Changed"
UniqueID=INTEGER|753778116
assign=STRING|"0"
changekind=STRING|"1"
devicekind=STRING|"1"
useparameter=STRING|"0"
Save the task text to a file and use the Task->Import menu to import the task into RoboTask.
Don't forget to enable the task after importing
