system variable cannot get the value, how to use it?
robotask813
Post by robotask813 »
{TaskComment}, the value of this system variable is empty, how to use it? Please give an example.
Re: system variable cannot get the value, how to use it?
{TaskComment} variable returns the comment/notes of this task
The variable works only in task context. Otherwise it returns the empty value
Look at the task below.
Save the task text to a file and use the Task->Import menu to import the task into RoboTask.
CatID=INTEGER|1445264190
ExternalName=STRING|"Task1575"
ID=INTEGER|-1045843217
Name=STRING|"Show ""{TaskComment}""..."
StepPause=INTEGER|0
Name=STRING|"Show ""{TaskComment}"""
msg0=STRING|"{TaskComment}"
[\Comment]
s1=Hello world!!!
s2=Just some text in task comment (look at "Notes" tab in task editor)
