put date into text
reboot619
put date into text
Post by reboot619 »
I want to be able to type yyy into any text that I'm writing and have robotask put today's date as yyyy-mm-dd
Re: put date into text
Now you can enter the date into the current input field by pressing the hotkey
Look at the task below. Press CTRL+ALT+D, and the task will enter the date into your text
Save the task text to a file and use the Task->Import menu to import the task into RoboTask.
You can also simply copy the task text and paste it into the task list.
Don't forget to enable the task after importing it.
CatID=INTEGER|694629558
ExternalName=STRING|"Task869"
ID=INTEGER|122602457
Name=STRING|"Insert date"
StepPause=INTEGER|0
currentwindow=STRING|"1"
fixedwindow=STRING|"1"
keylayout=STRING|"0"
keys=STRING|"{Year}-{MonthNo}-{Day}"
pause=STRING|"20"
release=STRING|"1"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
Name=STRING|"Ctrl+Alt+D"
UniqueID=INTEGER|598052594
hotkey=STRING|"49220"
