Logging with FTP synchronization
I use "FTP Synchronization" in a task. The loglevel is "All messages", but I don't see which are files are being synced, just this:
It should be nice to see actually what happened.
Re: Logging with FTP synchronization
FTP actions are deprecated and we have kept them for compatibility with older tasks.
I recommend you to use SSL FTP actions instead. The actions also support the simple FTP protocol.
The "SSL FTP Synchronization" action allows you to log the synchronization process.
Thanks for the heads-up. I will use it.
Unless the other side doesn't support it....... :evil:
How did you get the empty folder name (see screenshot)? The message must contain the folder name...
Could you please send me your task and the complete task log by email?
