Open image in webp-format
sarnusch
Post by sarnusch »
Good morning,
We receive many images in 'webp' format from our suppliers.
Unfortunately, the following error appears when opening the images with RoboTask:
Screenshot 2025-07-29 103656.png (10.03 KiB) Viewed 41150 times
The image can be opened by windows windows photo viewer.
Is it possible to add functionality for this format?
Re: Open image in webp-format
What version of RoboTask do you use?
Could you send a couple problem images to me by email?
Also I want to take a look to your task and complete log file
sarnusch
Post by sarnusch »
I just sent the requested information to you via email.
H-m-m... It works
I used this task
CatID=INTEGER|307868550
ExternalName=STRING|"Task1466"
ID=INTEGER|-1868807918
Name=STRING|"WEBP  (myTest)"
StepPause=INTEGER|0
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"FILENAME"
date1=STRING|"20250729"
date2=STRING|"20250729"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"C:\temp\111\*.webp"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
expression=STRING|"3"
message=STRING|"{FILENAME}"
mode=STRING|"0"
ActionID=STRING|"A_GRAPHICS_OPEN_IMAGE"
Name=STRING|"Open image from '{FILENAME}'"
_rt_variables_produced=STRING|"ImgHeight,ImgWidth"
enable_cms=STRING|"0"
height_var=STRING|"ImgHeight"
image_file=STRING|"{FILENAME}"
source=STRING|"0"
width_var=STRING|"ImgWidth"
I get this log file
I: 29.07.2025 14:12:21: ****** Starting task: WEBP  (myTest) ******************
I: 29.07.2025 14:12:21: Executing "1.File Loop"
I: 29.07.2025 14:12:21: Executing "2.Log Message"
-: 29.07.2025 14:12:21: C:\temp\111\89930872.webp
I: 29.07.2025 14:12:21: Executing "3.Open image from '{FILENAME}'"
I: 29.07.2025 14:12:22: Executing "4.End Loop"
I: 29.07.2025 14:12:22: Executing "1.File Loop"
I: 29.07.2025 14:12:22: Executing "2.Log Message"
-: 29.07.2025 14:12:22: C:\temp\111\file_example_WEBP_250kB.webp
I: 29.07.2025 14:12:22: Executing "3.Open image from '{FILENAME}'"
-: 29.07.2025 14:12:22: C:\temp\111\file_example_WEBP_500kB.webp
-: 29.07.2025 14:12:22: C:\temp\111\file_example_WEBP_50kB.webp
-: 29.07.2025 14:12:22: C:\temp\111\WebP_550x292.webp
-: 29.07.2025 14:12:22: C:\temp\111\WebP_845x562.webp
I: 29.07.2025 14:12:22: Task executed successfully
The folder C:\temp\111 contains several WebP files including your "problem" file
sarnusch
Post by sarnusch »
the WEBP - codec was not installed on the server.
After installing it the error message disappeard.
Thanks for your support!
