Show active/ inactive in task search
sarnusch
Post by sarnusch »
Good morning,
it would be very useful for me if the search (Find the task...; Shift+CTRL+F) also showed whether the task is active or inactive.
I have several tasks that serve as backups and aren't active. Sometimes they have the same name. Then it is difficult to find the correct task in the search.
