Temporary File is not deleted from {TempDir}
sarnusch
Post by sarnusch »
Good morning,
I recognized an issue with action 'SQL Query to CSV file'.
I want to create a CSV file from sql data and then (if it exists) send it to an email-address.
I am using for example {TempDir}\test.csv as target file for the query results.
In the first run I have a result set and the email is sent with the correct CSV file in attachement.
The second run does have an empty result set but the email is sent with the file from the first run.
I checked 'Do not create file if query result is empty' but I assumed that files in temporary folder are deleted after the task ends properly.
I do not want to send empty files.
I also check if the file exists with '{FileExists({TempDir}\test.csv)}'. In my opinion this check should not find the file in the second run.
I: 13.06.2025 08:34:50: ****** Starting task: Test TEMP Datei ******************
I: 13.06.2025 08:34:50: Executing "1.SQL Query to CSV File"
I: 13.06.2025 08:34:50: Executing "2.If Then"
I: 13.06.2025 08:34:50: Executing "3.SMTP Send Email"
I: 13.06.2025 08:34:50: Executing "4.Else"
I: 13.06.2025 08:34:50: Task executed successfully
I: 13.06.2025 08:35:14: ****** Starting task: Test TEMP Datei ******************
I: 13.06.2025 08:35:14: Executing "1.SQL Query to CSV File"
W: 13.06.2025 08:35:14: The query returned an empty recordset
I: 13.06.2025 08:35:14: Executing "2.If Then"
I: 13.06.2025 08:35:14: Executing "3.SMTP Send Email"
I: 13.06.2025 08:35:14: Executing "4.Else"
I: 13.06.2025 08:35:14: Task executed successfully
I am using latest version:
RoboTask version 10.4.0.1192 (x64 edition)
Assembly version 10.4.0.316
This is my task:
CatID=INTEGER|1199727700
ExternalName=STRING|"Task41"
ID=INTEGER|-541250406
Name=STRING|"Test TEMP Datei"
StepPause=INTEGER|0
ActionID=STRING|"A_CSVFROMSQL"
Name=STRING|"SQL Query to CSV File"
connectionstring=STRING|"Provider=SQLOLEDB.1;Password=;Persist Security Info=True;User ID=;Initial Catalog=;Data Source="
customdateformat=STRING|"0"
dateformat=STRING|"yyyy-mm-dd hh:nn:ss"
delimiter=STRING|"2"
limitlength=STRING|"999"
notcreateifempty=STRING|"1"
override=STRING|"0"
paramcount=STRING|"0"
password=STRING|""
quotechar=STRING|"0"
sql=STRING|""
strictdelimiter=STRING|"1"
targetencoding=STRING|"0"
targetfilename=STRING|"{TempDir}\test.csv"
timeout=STRING|"60"
usefieldnames=STRING|"1"
uselimitlength=STRING|"1"
withmemo=STRING|"1"
value1=STRING|"{FileExists({TempDir}\test.csv)}"
Name=STRING|"SMTP Send Email"
attach0=STRING|"{TempDir}\test.csv"
attachcount=STRING|"1"
auth=STRING|"0"
charset=STRING|"windows-1250"
from=STRING|""
host=STRING|""
html=STRING|"1"
msg0=STRING|"<html>"
msg1=STRING|"<body>"
msg8=STRING|"</body>"
msg9=STRING|"</html>"
msgcount=STRING|"10"
password=STRING|""
port=STRING|""
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"0"
subject=STRING|"Test"
tlsmode=STRING|"0"
tlsver=STRING|"2"
to=STRING|""
user=STRING|""
xmailer=STRING|"RoboTask"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"Keine Daten vorhanden"
Re: Temporary File is not deleted from {TempDir}
Just remove file before SQL query.
Like this
CatID=INTEGER|307868550
ExternalName=STRING|"Task1466"
Name=STRING|"Test TEMP Datei (corrected)"
StepPause=INTEGER|0
Name=STRING|"Set variable ""_CsvFile"" with value ""{TempDir}\test.csv"""
_rt_variables_produced=STRING|"_CsvFile"
varname=STRING|"_CsvFile"
varvalue=STRING|"{TempDir}\test.csv"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{_CsvFile}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
override=STRING|"0"
password=STRING|"P6m8mu0ChGWAUczO5BVcnH5wYxpb4H6EmFndLP2BRmkO9ZAscL07XVk="
sql=STRING|"""Put SQL here"""
targetfilename=STRING|"{_CsvFile}"
timeout=STRING|"60"
withmemo=STRING|"1"
auth=STRING|"0"
html=STRING|"1"
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"0"
tlsmode=STRING|"0"
tlsver=STRING|"2"
Name=STRING|"Else"
