Continuously monitor Telegram.exe for Windows Notification Window and send and Email if the Notification Window is found
William H Gates III
Post by William H Gates III »
And a very good day to you Sir
I hope you are safe and doing very well Sir
I am trying to Evaluate ROBOTask for the following Task
I would like to create a Task in ROBOTask to Continuously Monitor and Send an Email whenever a Program called Telegram.exe Opens up a Windows Notification Window
I have already created the Email sending part and have tested that it works
I am at the part where I have to add in the Trigger Part
For the Trigger - I use Windows Watcher to Watch for the "Telegram" Caption Window
Now ever when I save my template
Nothing runs at all unless i click the run task now button
Meanwhile the Telegram.exe program has triggered a Windows Notification Window multiple times over and over
May I please kindly ask how can I get this Template to Continuously Run in the Background to monitor for a Telegram Notification Window and trigger an email sending event every time the Telegram.exe program opens a windows notification window
Hope to hear from you soon
Thank you very much for your time, help, patience and kind understanding
Kind Regards as Always Sir
Re: Continuously monitor Telegram.exe for Windows Notification Window and send and Email if the Notification Window is f
I created small test task (see below). It works.
But please note that Window Watcher trigger works only within your user session. Trigger don't see any windows in another user session
CatID=INTEGER|307868550
ExternalName=STRING|"Task1583"
ID=INTEGER|-1468908563
Name=STRING|"Catch telegram alert"
StepPause=INTEGER|0
msg1=STRING|"Hey, awake!"
msg2=STRING|"Telegram"
msgcount=STRING|"3"
expression=STRING|"3"
message=STRING|"Telegram notification !!!!"
mode=STRING|"0"
type=STRING|"1"
colorscheme=STRING|"0"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
kind=STRING|"0"
message=STRING|"Telegram alert!!!!"
position=STRING|"0"
title=STRING|"Telegram"
width=STRING|"330"
EventID=STRING|"E_WINDOW_WATCHER"
Name=STRING|"Window Watcher (TelegramDesktop)"
UniqueID=INTEGER|1190903316
assignvariable=STRING|"0"
child=STRING|"0"
classexact=STRING|"0"
exact=STRING|"0"
hidden=STRING|"0"
usecaption=STRING|"1"
useclass=STRING|"0"
useparameter=STRING|"0"
watchfor=STRING|"1"
wincaption=STRING|"TelegramDesktop"
winclass=STRING|"Qt51517QWindowToolSaveBits"
BettyJNorton
Post by BettyJNorton »
That's an interesting approach! I've found Windows Watcher can be finicky with consistently detecting window titles, especially with dynamic ones. Perhaps exploring alternative triggers like process monitoring or using Telegram's API might offer more reliability? It's worth considering if constant monitoring is truly necessary or if a more event-driven approach would be less resource-intensive.
