RoboTask 10.4 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 10.4 now
What's new in RoboTask 10.4:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
RoboTask 10.4
+ New plugin Word. New actions: + In the "Excel Save As" action, added PDF format and output of a separate sheet
+ Updated engine of ZipUnzip plugin. New features for ZIP actions:
  • ZIP64 format - ZIP file size is more than 2 Gb and the number of packed files is more than 65535.
  • Multivolume archive - popular archiver applications (e.g. 7Zip, WinRAR) also support multivolume archives.
  • Modern encryption algorithms for packed files
+ Log Message - added possibility to specify message type by expressions using variables
+ Added "Append" mode to SSL FTP Upload action
+ Added conversion of decimal integer to OCT, BIN, HEX and vice versa to the Value format action.
+ Added "Do not create file if query result is empty" option to the "SQL query to CSV file" action.
* The File Monitor trigger now uses global file time independent of time zone.
* Added "Test SQL" function to "DB Loop" action
- In Read Text File action, memory leak and appearance of garbage at the end of data were fixed.
- Removed the parasitic pause in dialog actions.
- Fixed a password saving issue in the "sFTP open" action with some password variants.
- Fixed some bugs when closing the main RoboTask window.
* Many other small optimizations, improvements and bug fixes.
Locked
