text on one line
photoevents
text on one line
Post by photoevents »
I have this text file with names seperated by ;
like
first;last;
I use CSV Open Data, Data Loop, convert to text and create file in mode append to write a new file that has the names like this:
first last
But my action creates a file like this:
first
last
How can I keep the two variables on one line?
see the simple script below
CatID=INTEGER|1189457273
ExternalName=STRING|"Task334"
ID=INTEGER|-1035998595
Name=STRING|"New test task"
StepPause=INTEGER|0
ActionID=STRING|"A_CSV_OPEN"
Name=STRING|"CSV Open Data"
commentchars=STRING|"#"
delimiter=STRING|"2"
encoding=STRING|"0"
filename=STRING|"S:\photoevents\2025\resources\Deelnemerslijst.csv"
headerline=STRING|"0"
linecount=STRING|"0"
quotechar=STRING|"0"
skipcomments=STRING|"0"
skipempty=STRING|"1"
skipfirst=STRING|"0"
source=STRING|"1"
strictdelimiter=STRING|"1"
ActionID=STRING|"A_CSV_LOOP"
Name=STRING|"CSV Data Loop"
_rt_variables_produced=STRING|"rownr,rowvalue"
conditionmode=STRING|"0"
conditionscount=STRING|"0"
encoding=STRING|"0"
Format=STRING|"0"
linevarname=STRING|"rowvalue"
rowvarname=STRING|"rownr"
source=STRING|"0"
ActionID=STRING|"A_CSV_READCELLS"
Name=STRING|"CSV Read Cells"
_rt_variables_produced=STRING|"familienaam,voornaam"
cellcount=STRING|"2"
col0=STRING|"1"
col1=STRING|"2"
encoding=STRING|"0"
row0=STRING|"{rownr}"
row1=STRING|"{rownr}"
source=STRING|"0"
val0=STRING|"voornaam"
val1=STRING|"familienaam"
ActionID=STRING|"A_TXT_UTF8"
Name=STRING|"UTF8 text --> Text"
_rt_variables_produced=STRING|"voornaam"
kind=STRING|"1"
line00000000=STRING|"{voornaam}"
lines=STRING|"1"
variable=STRING|"voornaam"
_rt_variables_produced=STRING|"familienaam"
kind=STRING|"1"
line00000000=STRING|"{familienaam}"
lines=STRING|"1"
variable=STRING|"familienaam"
Name=STRING|"Create text file S:\photoevents\2025\resources\namenlijst.txt"
encode=STRING|"1"
fileexists=STRING|"1"
filname=STRING|"S:\photoevents\2025\resources\namenlijst.txt"
line0=STRING|"{voornaam} {familienaam}"
suppress=STRING|"1"
withoutprefix=STRING|"1"
Re: text on one line
You need to cut off EOL symbols from variables voornaam and familienaam
Look at my example below.
Also pay attention:
You can read CSV file as UTF-8 file and remove UTF8 text --> Text steps at all
ExternalName=STRING|"Task398"
ID=INTEGER|2078034344
Name=STRING|"Corrected CSV task"
StepPause=INTEGER|0
Name=STRING|"Set variable ""InFile"" with value ""C:\TEMP\csv\InFile.csv"""
_rt_variables_produced=STRING|"InFile"
varname=STRING|"InFile"
varvalue=STRING|"C:\TEMP\csv\InFile.csv"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{familienaam}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
Name=STRING|"Create text file {OutFile}"
encode=STRING|"1"
filname=STRING|"{OutFile}"
suppress=STRING|"1"
Name=STRING|"Set variable ""OutFile"" with value ""C:\TEMP\csv\OutFile.txt"""
_rt_variables_produced=STRING|"OutFile"
varname=STRING|"OutFile"
varvalue=STRING|"C:\TEMP\csv\OutFile.txt"
encoding=STRING|"0"
filename=STRING|"{InFile}"
source=STRING|"1"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{OutFile}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
encoding=STRING|"0"
Format=STRING|"0"
source=STRING|"0"
col0=STRING|"1"
col1=STRING|"2"
encoding=STRING|"0"
source=STRING|"0"
kind=STRING|"1"
lines=STRING|"1"
kind=STRING|"1"
lines=STRING|"1"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{voornaam}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
photoevents
Okay, got it, thank you
