SQL Commands
villanrl
SQL Commands
Post by villanrl »
Hi Oleg.I'm interested in the SQL commands that are supported in robotask.  I've been trying to use dates in my select statment but with no luck.Thanks.  Russ V.
SQL Commands
Can you send the example of SQL statement, that you want to use? Also, what kind of database do you use?
villanrl
SQL Commands
Post by villanrl »
First I'm using Crystal Reports to generate the SQL statement.
Here is one that works that I believe is on a windows server going through ODBC.
SELECT dbo.ARCServices.*
FROM dbo.ARCServices
WHERE dbo.ARCServices.RecordStatus='i' AND
dbo.ARCServices.CreatedDate > '1/1/2006';
Next is a SQL table on a Unix machine going through an ODBC connection.
It works except when adding the WHERE clause
The error is:
E: 12/21/2006 1:26:14 PM: Driver]Expected lexical element not found: <identifier>
 SELECT "CHG_Change"."Category", "CHG_Change"."Create-date"
 FROM   "CHG:Change" "CHG_Change"
 WHERE  "CHG_Change"."Create-date">={ts '2006-10-01 00:00:01'}
If I change the WHERE to be
 WHERE  "CHG_Change"."Create-date">'1/1/2006'
then no records are returned.
Any Ideas?
SQL Commands
Try to write so:
dbo.ARCServices.CreatedDate > #1/1/2006#
You must write dates in SQL statement in such format:
for european format #DD/MM/YYYY#
for american format #MM/DD/YYYY#
The order of days and month number must be corresponding to your regional settings. See Control panel -> Regional and language options
