All Plugins invalid on startup
UniMatrix
Post by UniMatrix »
Robotask newbie here,
I installed Robotask x64 10.3.5.315 on WIndows Server 2022, just Next, Next, Finish.
On startup I get "E: 21-5-2025 09:12:17: Plugin "C:\Program Files\RoboTask\Plugins\xxxx\xxx.rtp" is invalid." for all plugins.
Googling, Event Viewer did not help me.
Re: All Plugins invalid on startup
I just tested this.
All plugins are loaded without errors
Look at the screenshot
RoboTask on 2022.png (192.5 KiB) Viewed 41347 times
You may have a very paranoid antivirus or some setting in your domain/local policy.
The startup log of RoboTask is below
I 5/22/2025 11:47:51 PM: **** Starting RoboTask 10.3.1.1183... ************************
I 5/22/2025 11:47:51 PM: Application mode (x64 edition)
I 5/22/2025 11:47:51 PM: Load plugins...
I 5/22/2025 11:47:51 PM: Plugin "General (v 10.3.0.392)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "Dialogs and Notifications (v 10.3.1.282)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "Files and Folders (v 10.3.5.388)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "Zip (v 10.3.0.236)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "Internet (v 10.3.0.285)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "FTP Commands (v 10.3.0.232)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "SSL FTP Commands (v 10.3.0.209)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "SFTP (SSH FTP) (v 10.3.4.153)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "Dial-Up (v 10.3.0.196)" is loaded
I 5/22/2025 11:47:51 PM: Plugin "Variables (v 10.3.0.239)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Task Commands (v 10.3.0.217)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Remote Task (v 10.3.0.49)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Loops And Flows (v 10.3.0.255)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Window (v 10.3.0.250)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "System Events (v 10.3.0.250)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "System Functions (v 10.3.0.223)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "RoboTask Commands (v 10.3.0.200)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Clipboard (v 10.3.0.210)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Mouse (v 10.3.0.210)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Registry (v 10.3.0.196)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Network (v 10.3.0.197)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "eMail (v 10.3.0.231)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Strings (v 10.3.0.141)" is loaded
I 5/22/2025 11:47:52 PM: Plugin "Embedded Chromium Browser (v 10.3.0.78)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Regular Expressions (v 10.3.0.160)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "ScreenShot (v 10.3.0.122)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "INI files (v 10.3.0.36)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "XML Document (v 10.3.0.96)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Script Tools (v 10.3.0.57)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Excel (v 10.3.0.89)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Sound Volume (v 10.3.0.67)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "DataBase (v 10.3.0.85)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "CSV Data (v 10.3.3.33)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Graphics (v 10.3.0.49)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "WebSockets (v 10.3.0.57)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Console Application (v 10.3.0.35)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Converter (v 10.3.0.14)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "HDD S.M.A.R.T. (v 10.3.0.10)" is loaded
I 5/22/2025 11:47:53 PM: Plugin "Command Line Utilities (v 10.3.0.34)" is loaded
I 5/22/2025 11:47:53 PM: Load tasks...
I 5/22/2025 11:47:53 PM: 42 tasks loaded
I 5/22/2025 11:47:53 PM: Trial mode. Network client is enabled.
I 5/22/2025 11:47:53 PM: Preparing of network client...
I 5/22/2025 11:47:53 PM: Done.
I 5/22/2025 11:48:53 PM: Trial mode. Network server is enabled.
I 5/22/2025 11:48:53 PM: Preparing of network server...
W 5/22/2025 11:48:53 PM: Server is not started due to server settings
UniMatrix
Post by UniMatrix »
Thanks Oleg, I will try disabling the AV, however we have multiple servers with the same AV and Robotask without this issue.
Disabling AV did not help. Nor reinstalls, both from terminal and console.
Because we already decided to rebuild the server, just fo the hack of it, I removed the 64 bit version and installed the 32 bit version... which works :?
I'm not sure that it's AV. But the problem is somewhere in your system settings.
UniMatrix wrote: ↑Fri May 23, 2025 8:28 am ...
Probably you have plugins from another edition.
You must install one edition (x86 or x64) completely. If you have RoboTask.exe (x64) and plugins (from 32-bit edition), you will get exactly the same effect as you described in the beginning.
Moreover, it makes no sense to install both editions.
