Access violation in module 'rtl280.bpl'
sarnusch
Post by sarnusch »
Good morning,
the following error occured today in a task that runs every hour:
Screenshot 2025-04-25 081506.png (31.39 KiB) Viewed 42794 times
The task has been executed correctly one hour earlier and also after starting the task manually.
What is meant by 'Reconfigure the step'? Usually the task works fine.
RoboTask version: 10.3.1.1183 (x64 edition)
Re: Access violation in module 'rtl280.bpl'
I recommend you to restart RoboTask. And it would be great is you could email the task to me.
This is a standard message to get you to pay attention to this step.
sarnusch
Post by sarnusch »
I have sent the task to you via mail.
