TaskList
swilkinsUK
TaskList
Post by swilkinsUK »
Hi, is it possible within Robotask to retrieve a list of all active tasks? I'm working towards having a script job loop round that list and record for example {GetTaskCurrentStatus(<ExtName>)} into an external reporting database?
Re: TaskList
Yes, this is possible.
Look at my example
Then you can see it in task editor
CatID=INTEGER|307868550
ExternalName=STRING|"Task1568"
ID=INTEGER|6320754
Name=STRING|"Retrieve task list with status"
StepPause=INTEGER|0
Name=STRING|"Set variable ""OutFile"" with value ""{TempDir}\map.csv"""
_rt_variables_produced=STRING|"OutFile"
varname=STRING|"OutFile"
varvalue=STRING|"{TempDir}\map.csv"
ActionID=STRING|"A_TASK_LOGLEVEL"
Name=STRING|"Set task log level to ""All Messages"""
loglevel=STRING|"3"
mode=STRING|"0"
Name=STRING|"Create text file {OutFile}"
[Actions\Action12\Params]
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{OutFile}"
line0=STRING|"{#CSVtext}"
suppress=STRING|"0"
withoutprefix=STRING|"0"
Name=STRING|"Show Text"
[Actions\Action13\Params]
autoclose=STRING|"0"
filename=STRING|"{OutFile}"
fromfile=STRING|"0"
linecount=STRING|"0"
timeout=STRING|"10"
title=STRING|"Task list"
colorscheme=STRING|"0"
defh=STRING|"0"
defw=STRING|"0"
duration=STRING|"20"
height=STRING|"150"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"This taks retrieves CSV file with information:{eol}- Task ID{eol}- Task Name{eol}- Task external name{eol}- Task status"
position=STRING|"3"
title=STRING|"{TaskName}"
width=STRING|"400"
Name=STRING|"VB Script"
expandvars=STRING|"0"
line00000000=STRING|"txt = """""
line00000001=STRING|"for i=0 to RoboTaskApp.TaskCount - 1 step 1"
line00000002=STRING|"  id = RoboTaskApp.TaskInfoID(i)"
line00000003=STRING|"  nam = RoboTaskApp.TaskInfoName(i)"
line00000004=STRING|"  ext = RoboTaskApp.TaskInfoExtname(i)"
line00000005=STRING|"  status = RoboTaskApp.TaskInfoState(i)"
line00000007=STRING|"  filename = Hex(id)"
line00000008=STRING|"  while len(filename) < 8"
line00000009=STRING|"    FileName = ""0"" + FileName"
line0000000A=STRING|"  wend"
line0000000C=STRING|"  select case status"
line0000000D=STRING|"    case 0 st_string = ""Manual ("" + cstr(status) + "")"""
line0000000E=STRING|"    case 1 st_string = ""Idle ("" + cstr(status) + "")"""
line0000000F=STRING|"    case 2 st_string = ""Disabled/Busy ("" + cstr(status) + "")"""
line00000010=STRING|"    case 3 st_string = ""Running ("" + cstr(status) + "")"""
line00000011=STRING|"    case 4 st_string = ""Stopping ("" + cstr(status) + "")"""
line00000012=STRING|"  end select"
line00000013=STRING|"  'txt = txt + RoboTaskApp.ExpandText(""{TaskFolder}"") + ""\"" + filename + _"
line00000014=STRING|"  ' "".tsk = "" + nam + chr(13) + chr(10)"
line00000015=STRING|"  txt = txt + filename + ""|"" + nam + ""|"" + ext + ""|"" + st_string + chr(13) + chr(10)"
line00000016=STRING|"next"
line00000018=STRING|"RoboTaskApp.SetUserVariable ""text"", txt"
linecount=STRING|"26"
savescript=STRING|"0"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{#text}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"text"
Name=STRING|"Create local variable ""CSVTEXT"" with value """""
varname=STRING|"CSVTEXT"
Name=STRING|"Set task log level to ""Errors And Warnings"""
loglevel=STRING|"2"
mode=STRING|"0"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{#text}"
sourcetext=STRING|"1"
colon=STRING|"0"
comma=STRING|"0"
other=STRING|"1"
otherchar=STRING|"|"
quote=STRING|"0"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{#Line}"
tab=STRING|"0"
variable=STRING|"Line"
Name=STRING|"Set variable ""CSVTEXT"" with value ""{#CSVText}{#Line}{EOL}"""
varvalue=STRING|"{#CSVText}{#Line}{EOL}"
