Trigger task when user is not logged on (or locked)
fatt.lib
Post by fatt.lib »
Hello...
I've just started the evaluation in order to adopt roboTask in our environment.
I was wondering if a task can be triggered when no user is logged on.
Also what about atriggering a task when the logged on user is locked?
Thank you in advace for any advice!
Re: Trigger task when user is not logged on (or locked)
...a task can be triggered when no user is logged on.
Use system service mode. Read here (and related chapters) about service mode of RoboTask
You can set RoboTask System service and setup initial parameters by RoboTask Service Manager.
If task has some trigger it will running automatically
Locked session is similar to SYSTEM session. The task can be triggered automatically or via network remotely from remote RoboTask.
But pay attention that locked and SYSTEM sessions has some restrictions: system ignores mouse and keyboard simulation. This is the property of system security and you can not change this.
fatt.lib
Post by fatt.lib »
Thank you for the explanation.
Unfortunately mouse and keyboard simulation are needed for the activity I'm testing Robotask, therefore I'm going to setup a test with an user section not locked, paying attention to ensure it does not lock!
Unfortunately mouse and keyboard simulation are needed for the activity...
In this case you can use RoboTask in unlocked user session only.
emelialucass
Post by emelialucass »
I’m setting up a test with an unlocked user section, taking care to ensure it remains that way.
EmmaAlva
Post by EmmaAlva »
The task can be triggered automatically or remotely over a network via another RoboTask.
