Delete empty lines from text
sarnusch
Post by sarnusch »
I want to delete empty lines from a text in e.g. a variable.
The text looks like:
14,108,114,248,387
34
31
350
250
Unfortunatly I did not find an easy way to just delete the empty lines from the text and save the text without the empty lines as follows:
14,108,114,248,387
34
31
350
250
Could you please give me a hint?
Re: Delete empty lines from text
Look at the example below
ExternalName=STRING|"Task1464"
ID=INTEGER|-1755582636
Name=STRING|"remove empty lines from text"
StepPause=INTEGER|0
Name=STRING|"Set variable ""oldText"" with value ""14,108,114,248,387"""
_rt_variables_produced=STRING|"oldText"
linecount=STRING|"7"
varname=STRING|"oldText"
varvalue=STRING|"14,108,114,248,387"
varvalue00000002=STRING|"34"
varvalue00000004=STRING|"31"
varvalue00000005=STRING|"350"
varvalue00000006=STRING|"250"
Name=STRING|"Set variable ""NewText"" with value """""
_rt_variables_produced=STRING|"NewText"
linecount=STRING|"0"
varname=STRING|"NewText"
Name=STRING|"Text Loop"
_rt_variables_produced=STRING|"line"
delimiter_no=STRING|"0"
destvar=STRING|"line"
line0=STRING|"{oldText}"
quote_char=STRING|"0"
sourcetext=STRING|"1"
strict_delim=STRING|"1"
operator=STRING|"8"
value1=STRING|"{line}"
Name=STRING|"Set variable ""NewText"" with value ""{NewText}{line}{EOL}"""
varvalue=STRING|"{NewText}{line}{EOL}"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{NewText}"
spaces=STRING|"0"
tabs=STRING|"0"
trailing=STRING|"1"
variable=STRING|"NewText"
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"Old text:"
line00000001=STRING|"****************"
line00000002=STRING|"{oldText}"
line00000003=STRING|"****************"
line00000005=STRING|"New text:"
line00000006=STRING|"****************"
line00000007=STRING|"{NewText}"
line00000008=STRING|"****************"
linecount=STRING|"9"
timeout=STRING|"10"
