RoboTask 10.3 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 10.3 now
What's new in RoboTask 10.3:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
RoboTask 10.3
+ New action "Excel remove Row/Column"
+ New action "Date-Time functions".
+ New action "Add working days to date"
+ Added {TextFileAutoEncoding(<file_name>)} variable that tries to determine the encoding if BOM is not present
+ Log dialog action - added menu items to select each log window.
+ The "System Information" section was supplemented with information about RoboTask parameters
+ Added "Root Folder" parameter to "Pack Files" action. Allows not to change the current folder if you need to preserve folder structure when packing a separate folder
+ Added function of removing rows by number to the "CSV Remove columns" action
+ Added output of number of tasks for remote RoboTask connection.
+ Added default credentials mode to the "Login to network share / Map network drive" action
+ Added "Enable Color Management" option to "Open Image" action
* Optimized user interface of RoboTask settings. All settings have been moved to one dialog box
* Optimized user interface of "RoboTask service manager"
* Improved step filter in the task editor.
- Fixed a bug in the "SQL Query to CSV File" action when using variables in the query parameters.
* Many other small optimizations, improvements and bug fixes.
Locked
