jan
Posts: 29 Joined: Wed Jan 22, 2025 4:36 pm
Post
by jan » Wed Jan 29, 2025 1:52 pm
Hello Oleg,
I am trying to open an Excel file and read certain values from the last row. Opening the Excel file works, but it closes immediately after opening. I do not understand this. I am attaching the code:
CatID=INTEGER|0
ExternalName=STRING|"Task5"
ID=INTEGER|1912908470
Name=STRING|"Excel"
StepPause=INTEGER|0
filename=STRING|"Z:\BIZ\ECO\Contract\25\2025_Contract_Managment.xlsm"
hide=STRING|"0"
mode=STRING|"0"
tryconnect=STRING|"1"
ActionID=STRING|"A_EXCEL_GET"
Enabled=INTEGER|0
Name=STRING|"Excel Get Cells"
cell00000000=STRING|"22"
var00000000=STRING|"jb"
worksheet=STRING|"1"
Posts: 3225 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Wed Jan 29, 2025 2:17 pm
If you open a document in a task, the task closes the document when the task is finished.
Use
Run Program/Open Document . Also put some pause after it. EXCEL must have a time to open document.
Then, you can connect to already opened document by
Excel Open Document action
jan
Post
by jan » Wed Jan 29, 2025 2:40 pm
Hello Oleg,
Thank you very much. Now I would like to read all cells from column A whose cell content begins with DE01 or SK01 or SK02 or SK03. For each of the above cells in column A, I would like to read all the cells in column B.
Column A Column B
DE012014070 ENDR
EN012016022 STEL
DE012019014 STAU
SK032020012 ERLA
SK012020024 ALTO
These values are to be saved in a CSV file.
EN012014070;ENDR
EN012016022;STEL
EN012019014;STAU
SK032020012;ERLA
SK012020024;ALTO
The CSV file is to be cleaned of duplicates.
Is that possible and could you help?
Best regards, Ján
Post
by Oleg » Wed Jan 29, 2025 2:55 pm
I would like to read all cells from column A whose cell content begins with DE01 or SK01 or SK02 or SK03 .
Why does your example of CSV contain EN01 lines?
EN012014070;ENDR
EN012016022;STEL
EN012019014;STAU
SK032020012;ERLA
SK012020024;ALTO
jan
Post
by jan » Wed Jan 29, 2025 3:01 pm
Hello Oleg,
unfortunately that was my mistake.
Column A Column B
DE012014070 ENDR
DE012016022 STEL
DE012019014 STAU
SK032020012 ERLA
SK012020024 ALTO
Analog in the CSV file:
DE012014070;ENDR
DE012016022;STEL
DE012019014;STAU
SK032020012;ERLA
SK012020024;ALTO
Post
by Oleg » Thu Jan 30, 2025 12:41 pm
look at my example below.
... all cells from column A whose cell content begins with DE01 or SK01 or SK02 or SK03
In this case it's better to use regular expressions. This is universal method
ExternalName=STRING|"Task19"
ID=INTEGER|-402748910
Name=STRING|"Load XLS and make CSV"
StepPause=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Name=STRING|"Set variable ""xlsDoc"" with value ""C:\temp\csv\Book1.xlsx"""
_rt_variables_produced=STRING|"xlsDoc"
varname=STRING|"xlsDoc"
varvalue=STRING|"C:\temp\csv\Book1.xlsx"
Name=STRING|"RegExp Match \\ begins with DE01 or SK01 or SK02 or SK03 only"
_rt_variables_produced=STRING|"match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{a_cell}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"^(DE01|SK01|SK02|SK03)"
savesubexpression=STRING|"0"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"match"
[Actions\Action12\Params]
value1=STRING|"{match}"
Name=STRING|"Set variable ""CSV"" with value ""{CSV}{a_cell};{b_cell}{eol}"""
[Actions\Action13\Params]
_rt_variables_produced=STRING|"CSV"
varname=STRING|"CSV"
varvalue=STRING|"{CSV}{a_cell};{b_cell}{eol}"
[Actions\Action14]
[Actions\Action15]
[Actions\Action16]
ActionID=STRING|"A_EXCEL_CLOSE"
Name=STRING|"Excel Close"
[Actions\Action17]
Name=STRING|"Show Text"
[Actions\Action17\Params]
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"{CSV}"
timeout=STRING|"10"
filename=STRING|"{xlsDoc}"
hide=STRING|"0"
mode=STRING|"0"
tryconnect=STRING|"0"
Name=STRING|"Set variable ""num"" with value ""1"""
_rt_variables_produced=STRING|"num"
varname=STRING|"num"
varvalue=STRING|"1"
Name=STRING|"Set variable ""CSV"" with value """""
linecount=STRING|"0"
Name=STRING|"While loop"
value1=STRING|"true"
cell00000000=STRING|"A{num}"
cell00000001=STRING|"B{num}"
count=STRING|"2"
var00000000=STRING|"A_cell"
var00000001=STRING|"B_cell"
incement=STRING|"1"
vaiable=STRING|"num"
operator=STRING|"7"
value1=STRING|"{a_cell}"
Name=STRING|"Break"
jan
Post
by jan » Tue Feb 18, 2025 12:17 pm
Hello Oleg,
despite the lack of time, I would like to reply briefly to your message. First of all, thank you for your efforts. I tested your suggestion a week ago. However, nothing is written to the CSV.
But I will get back to you with this.
Best regards
Ján
