Use variable in 'SQL Query to CSV File'
sarnusch
Post by sarnusch »
Good morning,
I am trying to use a variable ({STORE}) with an integer value in 'SQL Query to CSV File' action.
Screenshot 2025-01-28 105217.png (6.96 KiB) Viewed 114318 times
But it always shows an error:
Screenshot 2025-01-28 105131.png (7.09 KiB) Viewed 114318 times
It seems that variables are not working in 'SQL Query to CSV File' action.
The same setup works fine in 'Dataset Loop' action.
Can you please investigate?
Re: Use variable in 'SQL Query to CSV File'
Thank you for the report. It seems this is a bug. We'll fix it
Now you can include RoboTask variables directly in SQL expression
For example:
select * from addr where locked = {num}
LucasGaines
Post by LucasGaines »
Has the admin fixed the core yet. My screen still shows the error.
LucasGaines
space waves
LucasGaines wrote: ↑Thu Apr 03, 2025 4:40 am Has the admin fixed the core yet. My screen still shows the error.
This problem has been fixed in version 10.3 (current version)
Send your task to me in private message or publish the text of your task here.
It's hard to say anything without your task
