Action "Windows Watcher" does not close all Outlook windows
jan
Post by jan »
Good morning everyone and a good start to the new week,
In order for a certain robot task to work for me, I have to check if MS Office windows are displayed and then always confirm them. These windows ultimately allow a piece of software to access MS Outlook. Since there can be more than one window, I try to do this with a loop. I manage to confirm access for one window, but the second window is not automatically processed.
It would be sufficient to run this task 6 minutes after Windows starts.
CatID=INTEGER|0
ExternalName=STRING|"Task6"
ID=INTEGER|-873706518
Name=STRING|"Process Window of MS Office"
StepPause=INTEGER|0
ActionID=STRING|"A_LOOP_WINDOW"
Name=STRING|"Window Loop"
_rt_variables_produced=STRING|"MSHandle,MSName"
caption=STRING|"1"
captionexact=STRING|"1"
captionfilter=STRING|"1"
captionvalue=STRING|"Microsoft Outlook"
captionvariable=STRING|"MSName"
class=STRING|"0"
classexact=STRING|"1"
classfilter=STRING|"1"
classvalue=STRING|"#32770"
handlevariable=STRING|"MSHandle"
showchild=STRING|"0"
showhidden=STRING|"0"
Name=STRING|"Focus window ""Microsoft Outlook"""
action=STRING|"0"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"1"
classexact=STRING|"0"
exact=STRING|"1"
findmode=STRING|"0"
hidden=STRING|"0"
processall=STRING|"1"
wincaption=STRING|"Microsoft Outlook"
winclass=STRING|"#32770"
ActionID=STRING|"A_MOUSE_MOVETO"
Name=STRING|"Move Mouse To An Object"
bottom=STRING|"173"
controlclass=STRING|"Button"
controltext=STRING|"Erteilen"
ctrlclassexact=STRING|"1"
ctrltextexact=STRING|"1"
left=STRING|"55"
right=STRING|"131"
top=STRING|"150"
winclassexact=STRING|"1"
windowclass=STRING|"#32770"
windowtext=STRING|"Microsoft Outlook"
wintextexact=STRING|"1"
x=STRING|"44"
y=STRING|"11"
Name=STRING|"Click left button"
action=STRING|"0"
button=STRING|"0"
Re: Processing MS Office windows
... but the second window is not automatically processed.
Maye you have some error/warning messages?
Also I made some corrections in your task.
1. Use window handle. The loop can obtain window handle. It is an ID of window, so you don't need to find window again by caption and class
2. I put the pause between steps 300 ms, because you want to use interactive actions. Look at the Task editor->Settings tab->Pause between steps parameter
The pause is necessary to give the app time to react to your actions.
ExternalName=STRING|"Task1565"
ID=INTEGER|1059341744
Name=STRING|"Process Window of MS Office (corrected)"
StepPause=INTEGER|300
_rt_variables_produced=STRING|"MSHandle"
caption=STRING|"0"
class=STRING|"0"
Name=STRING|"Focus window by handle"
action=STRING|"0"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"1"
exact=STRING|"1"
findmode=STRING|"1"
handle=STRING|"{MSHandle}"
hidden=STRING|"0"
bottom=STRING|"173"
left=STRING|"55"
right=STRING|"131"
top=STRING|"150"
x=STRING|"44"
y=STRING|"11"
action=STRING|"0"
button=STRING|"0"
I don't know your goal, but maybe it's better to send ENTER key to active window instead of Move to object and Mouse click
jan
Post by jan »
Hello Oleg,
Thank you very much for your super-fast reply. I am attaching a picture of the window. "Grant" (in German "Erteilen") must be clicked in the window. Nothing else.
One question: Is it possible to monitor when the window appears or whether the window exists? If so, there would be no need to wait 6 minutes, but the window could be processed immediately after it appears.
Best regards from Munich
Ján
Maybe to send two keys to current window: LEFT ARROW and ENTER. Try this.
Look at the Window Watcher trigger
jan
Post by jan »
Hello Oleg,
Thank you very much, I'm testing it. But it's not working yet.
Ján
Why? Can you do it manually?
jan
Post by jan »
Hello Oleg,
I had to put a trigger "Cyclic" (in this case 10 seconds) before the "Windows Watcher" so that all windows are processed. Unfortunately, after all windows have been processed, the trigger is useless and consumes resources. Is there another way to do this?
Best regards, Ján
CatID=INTEGER|0
ContinueOnError=INTEGER|1
ExternalName=STRING|"Task2"
ID=INTEGER|-1438924388
Name=STRING|"Allow ""Automatic Email Processor"" to access Outlook  (imported)"
RunOnStartup=INTEGER|1
StepPause=INTEGER|500
caption=STRING|"0"
class=STRING|"0"
showchild=STRING|"1"
showhidden=STRING|"1"
action=STRING|"0"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"1"
exact=STRING|"1"
findmode=STRING|"1"
hidden=STRING|"0"
currentwindow=STRING|"1"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"{LEFT}{ENTER}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
Event2=FOLDER
Name=STRING|"Cyclic (every 10 sec)"
UniqueID=INTEGER|-1949175563
interval=STRING|"10"
[Events\Event2]
EventID=STRING|"E_WINDOW_WATCHER"
Name=STRING|"Window Watcher (Microsoft Outlook)"
UniqueID=INTEGER|-1764923589
[Events\Event2\Params]
assignvariable=STRING|"0"
child=STRING|"1"
exact=STRING|"1"
hidden=STRING|"1"
usecaption=STRING|"1"
useclass=STRING|"1"
useparameter=STRING|"0"
watchfor=STRING|"1"
you can remove Window Watcher trigger from your task
jan
Post by jan »
Good morning Oleg,
I don't understand your recommendation. You recommend me to remove the trigger "Window Watcher" from the task, so that only the trigger "cyclic" is included in the task.
What I wanted to say with yesterday's post is, that processing the Outlook-windows works, but the trigger "cyclic" (here every 10 seconds), after it has fulfilled its task (which is about 30 seconds after Windows startup) is of no use anymore and unnecessarily costs computer resources. I therefore asked for a different solution and how often the "Windows Watcher" trigger checks whether a window is present.
Can you help me again? Many greetings wherever you are at home.
CatID=INTEGER|0
Name=STRING|"Allow ""Automatic Email Processor"" to access Outlook (10 s)"
caption=STRING|"0"
class=STRING|"0"
action=STRING|"0"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"1"
exact=STRING|"1"
findmode=STRING|"1"
hidden=STRING|"0"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
Event2=FOLDER
[Events\Event2]
child=STRING|"1"
exact=STRING|"1"
hidden=STRING|"1"
useclass=STRING|"1"
watchfor=STRING|"1"
