jan
Posts: 29 Joined: Wed Jan 22, 2025 4:36 pm
Post
by jan » Sun Jan 26, 2025 1:17 pm
Hello everyone,
I would like to check cyclically whether a certain program "A" is running. If it is not running, a certain program "B" should be closed if it is running and "A" should be started automatically. My code does not seem to work:
CatID=INTEGER|0
ExternalName=STRING|"Task1"
ID=INTEGER|-1927680902
Name=STRING|"Ensure ""Automatic Email Processor"" is running"
StepPause=INTEGER|0
ActionID=STRING|"A_MISC_WAITPROCESSSTART"
Name=STRING|"Wait for process ""C:\Program Files (x86)\Automatic Email Processor\AutomaticEmailProcessor.exe"" start (1 sec)"
_rt_variables_produced=STRING|"AEP"
infinity=STRING|"0"
process=STRING|"C:\Program Files (x86)\Automatic Email Processor\AutomaticEmailProcessor.exe"
timeout=STRING|"1"
waitresult=STRING|"1"
waitresultvar=STRING|"AEP"
operator=STRING|"1"
value1=STRING|"{AEP}"
value2=STRING|"0"
ActionID=STRING|"A_MISC_KILLAPP"
Name=STRING|"Terminate process ""C:\Program Files (x86)\Automatic Email Processor\AEPProcessor.exe"""
more=STRING|"2"
process=STRING|"C:\Program Files (x86)\Automatic Email Processor\AEPProcessor.exe"
Name=STRING|"Delay 10 sec"
delay=STRING|"10"
dimension=STRING|"1"
Name=STRING|"Run ""AutomaticEmailProcessor.exe """
ifnonzero=STRING|"0"
program=STRING|"C:\Program Files (x86)\Automatic Email Processor\AutomaticEmailProcessor.exe"
runas=STRING|"2"
wait=STRING|"0"
Name=STRING|"Cyclic (every 600 sec)"
UniqueID=INTEGER|1994471606
interval=STRING|"600"
Posts: 3225 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Sun Jan 26, 2025 2:02 pm
Look at my example below
ExternalName=STRING|"Task1562"
ID=INTEGER|-1972044874
Name=STRING|"Ensure ""Automatic Email Processor"" is running (version 2)"
StepPause=INTEGER|0
Name=STRING|"Set variable ""programA"" with value ""C:\Program Files (x86)\Automatic Email Processor\AutomaticEmailProcessor.exe"""
_rt_variables_produced=STRING|"programA"
varname=STRING|"programA"
varvalue=STRING|"C:\Program Files (x86)\Automatic Email Processor\AutomaticEmailProcessor.exe"
delay=STRING|"10"
Name=STRING|"Run ""{programA} """
[Actions\Action12\Params]
program=STRING|"{programA}"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Set variable ""programB"" with value ""C:\Program Files (x86)\Automatic Email Processor\AEPProcessor.exe"""
_rt_variables_produced=STRING|"programB"
varname=STRING|"programB"
varvalue=STRING|"C:\Program Files (x86)\Automatic Email Processor\AEPProcessor.exe"
Name=STRING|"If Then //if programA is running"
value1=STRING|"{IsProcessExists({programA})}"
Name=STRING|"If Then // if programB is not running"
operator=STRING|"1"
value1=STRING|"{IsProcessExists({programB})}"
Name=STRING|"Run ""{programB} """
program=STRING|"{programB}"
runas=STRING|"0"
wait=STRING|"0"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"If Then // if programB is running"
Name=STRING|"Terminate process ""{programB}"""
more=STRING|"2"
process=STRING|"{programB}"
UniqueID=INTEGER|1442990722
jan
Post
by jan » Sun Jan 26, 2025 6:13 pm
Oleg, many thanks for the quick help. It works great.
Best regards, Ján
P.S. Can you please help me with my other problem too, where I want to write numbers in a Word document and then print a PDF?
Best regards from Munich
FrederickWilkins
Posts: 1 Joined: Wed Apr 09, 2025 3:19 am
Post
by FrederickWilkins » Wed Apr 09, 2025 3:25 am
It took me a long time to fix this. Thank goodness this thread and Oleg's reply helped me.
