Writing characters in a Word document
jan
Post by jan »
Hello everybody,
I would like to automatically create a PDF cover sheet for a PDF invoice collection. A Word template is to be opened for this purpose. Numbers are to be written in two places in the Word template. Then a PDF is to be saved.
So the steps are:
1. another software creates a yearly folder each year (e.g. 2025) and a monthly folder each month (e.g. 01) before the aforementioned software saves a PDF invoice (e.g. XYZ.pdf) in a subfolder (e.g. ...\2025\01\Invoice\OUT\XYZ.pdf)
2. robotask should now open a Word template for each monthly folder (e.g. 01)
3. have Robotask write the current month as a two-digit number at a specific position in the Word document (e.g. 01)
4. have Robotask write the current year as a four-digit number at a certain point in the Word document (e.g. 2025)
5. have Robotask create a "Data" folder in the month folder (e.g. ...\2025\01\Data)
6. robotask should save a PDF of the Word document in the "Data" folder (e.g. ...\2025\01\Data\Cover page.pdf)
Is this possible? If so, how?
I would be very grateful for your help.
best regards, Ján
jan
Re: Writing characters in a Word document
Post by jan »
Good morning everyone,
Is there anyone here who can answer my question, please?
Best regards, Ján
These are very vague requirements
... two-digit number at a specific position ...
... four-digit number at a certain point ...
Where are these positions?
A Word document can have a very different structure from simple text to a very complex format.
In an EXCEL document, for example, you can clearly specify the coordinates of a cell. In a WORD document, you cannot do this
jan
Post by jan »
Hello Oleg,
Thank you for your reply. In the Word document, two numbers are to be changed on the first page and then a PDF is to be printed.
After careful consideration, the problem could be solved using XML files with defined placeholders. I have already tried this with other software. Unfortunately, this software does not yet allow printing to PDF.
Best regards
Ján
sarausa
Post by sarausa »
You need to install a virtual PDF printer on your computer, then Robotask can print to PDF files. Slither io
jan
Post by jan »
Thank you for your help.
