Packing error
MagicX
Packing error
Post by MagicX »
Hi,when using the "Junk
Folder Names" option, zip packing fails.Alexander
Packing error
Maybe some subfolder contain file with same name as in parent folder (or in another subfolder). This option is working fine when all names of files are unique. Also you can turn off "Include subfolder" option.
MagicX
Packing error
Post by MagicX »
Was my fault, i thought the option would truncate the path name leading to the parent. Because currently packages have the full root folder information embeded, not really usefull for distributions.I build around it for now, by not using the integrated packing option.Alexander
Packing error
Also you can do so:
change folder
pack files *.* with subfolders
This algorithm packs files without full path names, only from current folder.
