Delete pdf files by part of file name
jan
Post by jan »
Hello everyone,
I would like to delete all PDF files in a folder that have __done in the file name and are older than 2 months.
Robotask should check every hour whether the folder contains such files.
Would anyone be willing to help me with this? Many thanks in advance.
Best regards, Ján
Re: Delete pdf files by part of file name
Look at my example below. Also pay attention to Date filter of the loop.
The you can see it in task editor
CatID=INTEGER|45174721
ExternalName=STRING|"Task1540"
ID=INTEGER|1826496193
Name=STRING|"Delete PDF with part of name"
StepPause=INTEGER|0
Name=STRING|"Set variable ""PDFFolder"" with value ""D:\Temp\pdf"""
_rt_variables_produced=STRING|"PDFFolder"
varname=STRING|"PDFFolder"
varvalue=STRING|"D:\Temp\pdf"
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"FDF_File"
createmode=STRING|"4"
createormodified=STRING|"1"
date1=STRING|"20250123"
date2=STRING|"20250123"
destvar=STRING|"FDF_File"
DuringMinutes=STRING|"1"
file0=STRING|"{PDFFolder}\*_done*.pdf"
OlderMonths=STRING|"2"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
message=STRING|"{FDF_File}"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{FDF_File}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"1"
jan
Post by jan »
Hi Oleg,
Thanks for your answer and your effort. Since I am an absolute beginner, I have to ask how I can export the code to a *.tsk file. Can you please help me again?
best regards from Munich, Ján
Select the necessary task and use menu Task->Export
jan
Post by jan »
Hello Oleg,
I have managed to import the task into Robotask.
Thanks again for your great help!
Ján
