Can Robotask detect mouse movements?
covertkaput
Post by covertkaput »
Hello!
I am trying to build a break reminder on my computer, which gets activated based on mouse movements; that is, instead of showing a break reminder every 40 minutes, it'd start counting 40 minutes only after detection of mouse movement.
Re: Can Robotask detect mouse movements?
Look at the On Idle trigger. You can use it in reverse mode.
The trigger starts the task when you exit idle mode.
Put Pause 40 minutes as 1-st step of the task.
After pause you can put some alert
