FTP Synchronization missing files/folders
blimp4
Post by blimp4 »
Hello
With the "FTP Synchronization" action I'm trying to backup an FTP folder, but I see 2 issues for now :
1/ if at the source there's an empty folder, it's not created on the destination (even I've checked "Exact copy")
2/ it does not sync folders or files starting with a point (like .htaccess for instance)
Am I missing something?
Re: FTP Synchronization missing files/folders
FTP Synchrinization action copies files only now
Probably these files have HIDDEN or SYSTEM attribute
Now FTP File loop and FTP synchronization actions don't show hidden files
I've put your wishes into our ToDo list
Also one note: use SSL FTP actions instead of FTP actions.
SSL FTP supports both modes: SSL and plain FTP.
We kept a simple FTP plugin for compatibility with older tasks. It is obsolete.
blimp4
Post by blimp4 »
I've put your withes into our ToDo list
Thanks Oleg
Do you have way to be updated about new features? Subscribe to new annoucements for instance?
There is "Check for updates" module: menu Help->Check for updates
By default application checks new version every 7 days
