CSV DATA LOOP
photoevents
CSV DATA LOOP
Post by photoevents »
I have a csv file which is constantly being updated with new rows.
What I want to do is to copy this file over to a workfolder,
then loop it and do something with the variables
then repeat the process but now taking into account the lines that already have been processed.
I was thinking when opening CSV open Data to use a variable (linecounter) and put that in Skip first lines, so it starts in the next loop with the new lines added.
I'm a bit stuck
perhaps you could advice on a better approach?
Not that i need code just some advice,
CatID=INTEGER|345416516
ExternalName=STRING|"Task12"
ID=INTEGER|-267299765
Name=STRING|"CSV Open Data..."
StepPause=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Create global variable ""row_counter_total"" with value ""0"""
_rt_variables_produced=STRING|"row_counter_total"
varkind=STRING|"0"
varname=STRING|"row_counter_total"
varvalue=STRING|"0"
Name=STRING|"Show ""{voornaam}"""
msg0=STRING|"{voornaam}"
msg1=STRING|"{wens}"
msgcount=STRING|"2"
Name=STRING|"Delay 1 sec"
delay=STRING|"1"
dimension=STRING|"1"
Name=STRING|"Increment variable ""row_counter_total"""
[Actions\Action13\Params]
incement=STRING|"{var_row}"
vaiable=STRING|"row_counter_total"
[Actions\Action14]
Name=STRING|"Show ""{row_counter_total}"""
[Actions\Action14\Params]
msg0=STRING|"{row_counter_total}"
[Actions\Action15]
ActionID=STRING|"A_FLOW_GOTO"
Name=STRING|"GoTo step #2"
[Actions\Action15\Params]
step=STRING|"2"
uselabel=STRING|"0"
ActionID=STRING|"A_FLOW_LABEL"
Name=STRING|"Label: Label1"
name=STRING|"Label1"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
checkfile=STRING|"1"
destdir=STRING|"S:\onedrive_photoevents\photoevents\makeawish"
f_count=STRING|"1"
file0=STRING|"W:\WISH\MAKEAWISH\storage\csv\form-results.csv"
hidden=STRING|"0"
ifexists=STRING|"0"
maxtimeout=STRING|"5"
move=STRING|"0"
output=STRING|"0"
rename=STRING|"1"
renamemask=STRING|"form-results-workfile.csv"
subdir=STRING|"0"
system=STRING|"0"
ActionID=STRING|"A_CSV_OPEN"
Name=STRING|"CSV Open Data"
commentchars=STRING|"#"
delimiter=STRING|"0"
encoding=STRING|"0"
filename=STRING|"S:\onedrive_photoevents\photoevents\makeawish\form-results-workfile.csv"
headerline=STRING|"1"
linecount=STRING|"0"
quotechar=STRING|"0"
skipcomments=STRING|"0"
skipempty=STRING|"1"
skipfirst=STRING|"0"
source=STRING|"1"
strictdelimiter=STRING|"1"
ActionID=STRING|"A_CSV_INFO"
Name=STRING|"CSV Get Data Information"
_rt_variables_produced=STRING|"las_column_count,last_row_count"
colcountvar=STRING|"las_column_count"
delimiter=STRING|"2"
encoding=STRING|"0"
headerline=STRING|"0"
recordcountvar=STRING|"last_row_count"
source=STRING|"0"
Name=STRING|"Show ""{last_row_count} rows"""
msg0=STRING|"{last_row_count} rows"
msg1=STRING|"{las_column_count} columns"
msgcount=STRING|"2"
ActionID=STRING|"A_CSV_LOOP"
Name=STRING|"CSV Data Loop"
_rt_variables_produced=STRING|"var_row,var_value"
conditionmode=STRING|"0"
conditionscount=STRING|"0"
encoding=STRING|"0"
Format=STRING|"0"
linevarname=STRING|"var_value"
rowvarname=STRING|"var_row"
source=STRING|"0"
ActionID=STRING|"A_CSV_READCELLS"
Name=STRING|"CSV Read Cells"
_rt_variables_produced=STRING|"voornaam,wens"
cellcount=STRING|"2"
col0=STRING|"1"
col1=STRING|"3"
encoding=STRING|"0"
row0=STRING|"{var_row}"
row1=STRING|"{var_row}"
source=STRING|"0"
val0=STRING|"voornaam"
val1=STRING|"wens"
Thanks,
Christian
Re: CSV DATA LOOP
Which variable contains the number of lines processed? row_counter_total, correct?
1. In this case you don't need to create it in 1-st step. You must create it somewhere outside the task (for example manually)
2. You can simply skip processed rows
do something like this:
CSV data loop
   if {var_row} > {row_counter_total} then
      read cells
      do something else
   end if
end loop
3. I see that your task works indefinitely. This is a very bad idea. It's better to start task periodically. Look at the Cyclic trigger. For example every 5-10 seconds.
photoevents
Re: CSV DATA LOOP
Thank you,
That helps,
Again ;-)
Christian
photoevents
Re: CSV DATA LOOP
Everything works fine.
Except when trying the task using runtime on another computer, the cycle trigger doesn't work.
I just remember no triggers work at all.
For now I use a loop with pause, which works but is an endless loop which you think is not a good idea.
Any advice on how to do this better?
Christian
felipe
Re: CSV DATA LOOP
Post by felipe »
What do you think about storing the line variable in a .txt file alongside the CSV, including the machine ID in the file name? This way, multiple machines can read the CSV without conflicts.
Re: CSV DATA LOOP
Why? Maybe you have disabled automation of RoboTask at all. Check this please. Menu Tools->Enable automation.
If automation is disabled all triggers are stopped.
The RoboTask main window looks as follows when automation is enabled
The disabled automation looks as shown in the screenshot:
photoevents
Re: CSV DATA LOOP
I was referring to the runtime of robotask.
Christian
Re: CSV DATA LOOP
That's exactly where you should have started.
You can start RoboTask runtime in infinite loop by using simple CMD file
CTRL+C can break the loop. The text of CMD example is below
@echo off
set num=0
:begin
set /a num+=1
echo iteration #%num%
echo You can run Runtime module with your task here
rem Put here something
timeout 5
goto begin
This example runs your application/task every 5 seconds in infinite loop
