Running Programs Over The Network
gorgeous
Post by gorgeous »
Is their anyway to launch a program on another computer on the Network?
Re: Running Programs Over The Network
You need to install RoboTask on remote computer and send the command to remote RoboTask.
Look at the Send command action and Listener trigger
You can perform any action in the remote task, including launching any application.
ralphharper
Post by ralphharper »
Oleg wrote: ↑Fri Dec 20, 2024 1:03 pm You need to install RoboTask on remote computer and send the command to remote RoboTask. retro bowl
oh thank you, finally i found this.
Evangelin
Post by Evangelin »
Look at the Send command action and Listener triggerslope
Is it possible to set up RoboTask to automatically start a specific program on the remote computer at scheduled times, and if so, how can I configure the Listener trigger for that?
...how can I configure the Listener trigger for that?
Listener trigger launches the task. In the task you can run necessary program.
But please note that you must have installed RoboTask on both computers
