Pause/ Delay with variable value
sarnusch
Post by sarnusch »
Good morning,
I am using a REST API with a system for customer communication.
Sometimes I get an error '500' as response status code.
So I want to try an exponential backoff and repeat sending the request for a few times with longer intervals.
At the moment the Pause/ Delay action just allows me to enter a delay in milliseconds, seconds, minutes.
I can not enter a variable value that increases with my value.
Do I have another chance to create a delay in the task with a variable value?
Re: Pause/ Delay with variable value
You can use Simple loop. Look at my example below
Set necessary pause in seconds in the 1-st step
I think the algorithm is clear
ExternalName=STRING|"Task1453"
ID=INTEGER|-648954384
Name=STRING|"Custom pause"
StepPause=INTEGER|0
Name=STRING|"Set variable ""pause"" with value ""5"""
_rt_variables_produced=STRING|"pause"
varname=STRING|"pause"
varvalue=STRING|"5"
Name=STRING|"Set variable ""dt"" with value ""{DateTime}"""
_rt_variables_produced=STRING|"dt"
varname=STRING|"dt"
varvalue=STRING|"{DateTime}"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"{pause}"
step=STRING|"1"
Name=STRING|"Delay 1 sec"
delay=STRING|"1"
dimension=STRING|"1"
ActionID=STRING|"A_TIMEDIFFERENCE"
Name=STRING|"Time Difference"
_rt_variables_produced=STRING|"delay"
datetime1=STRING|"{dt}"
datetime2=STRING|"{DateTime}"
format=STRING|"0"
valuekind=STRING|"0"
varname=STRING|"delay"
Name=STRING|"Show ""Delay is {delay} seconds"""
msg0=STRING|"Delay is {delay} seconds"
sarnusch
Post by sarnusch »
thanks for the quick response.
I could already find another way to solve the problem.
I used the following process:
CatID=INTEGER|1199727700
StepPause=INTEGER|0
Name=STRING|"Set variable ""counter"" with value ""1"""
_rt_variables_produced=STRING|"counter"
varname=STRING|"counter"
varvalue=STRING|"1"
varvalue=STRING|"5"
Name=STRING|"While loop"
operator=STRING|"5"
type=STRING|"1"
value1=STRING|"{counter}"
value2=STRING|"4"
begin=STRING|"1"
step=STRING|"1"
delay=STRING|"1"
Name=STRING|"Increment variable ""counter"""
incement=STRING|"1"
vaiable=STRING|"counter"
Name=STRING|"Increment variable ""pause"""
incement=STRING|"5"
vaiable=STRING|"pause"
message=STRING|"{counter} - {pause} sec"
By the way, starting from version 6.8, the Pause action allows you to use variables in the pause field
Take a look at the example below
CatID=INTEGER|1897123812
ExternalName=STRING|"Task1478"
ID=INTEGER|493413889
Name=STRING|"Pause with variables"
StepPause=INTEGER|0
begin=STRING|"1"
end=STRING|"5"
step=STRING|"1"
Name=STRING|"Set variable ""p"" with value ""{RandomValue(5)}"""
_rt_variables_produced=STRING|"p"
varname=STRING|"p"
varvalue=STRING|"{RandomValue(5)}"
message=STRING|"{p}"
Name=STRING|"Delay {p} sec"
delay=STRING|"{p}"
