gremlin
Posts: 50 Joined: Sun Jan 08, 2023 3:13 pm
Post
by gremlin » Tue Nov 12, 2024 11:36 am
I have a problem with XML Get Node.
These nodes are not read:
<ADDRESS>
<bmecat:NAME2>Jacqueline - Test</bmecat:NAME2>
<bmecat:NAME3>Kales - Test</bmecat:NAME3>
<bmecat:STREET>Teststraße 9-13</bmecat:STREET>
<bmecat:ZIP>10179</bmecat:ZIP>
<bmecat:CITY>Berlin</bmecat:CITY>
<bmecat:COUNTRY>Deutschland</bmecat:COUNTRY>
<bmecat:COUNTRY_CODED>DE</bmecat:COUNTRY_CODED>
<bmecat:PHONE>089 - 24 24 11 55</bmecat:PHONE>
<bmecat:EMAIL>mail+m-f-ks37huh@mhhh.de</bmecat:EMAIL>
</ADDRESS>
it must be because of the
bmecat:NAME2
All other nodes without 'bmecat:' are processed successfully.
Do you have a solution for this?
Posts: 3316 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Tue Nov 12, 2024 12:16 pm
Your XML text contains some namespace -
bmecat
You must declare it. The action uses system engine to process XML and get an error without declaration
You can retrieve all node values in the loop. Look at my example below
ExternalName=STRING|"Task12"
ID=INTEGER|-2104715254
Name=STRING|"get nodes"
StepPause=INTEGER|0
Name=STRING|"Set variable ""xml"" with value ""<ADDRESS>"""
_rt_variables_produced=STRING|"xml"
linecount=STRING|"11"
varname=STRING|"xml"
varvalue=STRING|"<ADDRESS>"
varvalue00000001=STRING|" <bmecat:NAME2>Jacqueline - Test</bmecat:NAME2>"
varvalue00000002=STRING|" <bmecat:NAME3>Kales - Test</bmecat:NAME3>"
varvalue00000003=STRING|" <bmecat:STREET>TeststraГџe 9-13</bmecat:STREET>"
varvalue00000004=STRING|" <bmecat:ZIP>10179</bmecat:ZIP>"
varvalue00000005=STRING|" <bmecat:CITY>Berlin</bmecat:CITY>"
varvalue00000006=STRING|" <bmecat:COUNTRY>Deutschland</bmecat:COUNTRY>"
varvalue00000007=STRING|" <bmecat:COUNTRY_CODED>DE</bmecat:COUNTRY_CODED>"
varvalue00000008=STRING|" <bmecat:PHONE>089 - 24 24 11 55</bmecat:PHONE>"
varvalue00000009=STRING|" <bmecat:EMAIL>mail+m-f-ks37huh@mhhh.de</bmecat:EMAIL>"
varvalue0000000A=STRING|" </ADDRESS>"
ActionID=STRING|"A_XML_LOOP"
Name=STRING|"XML Loop"
_rt_variables_produced=STRING|"nodeName,NodeText"
ascending=STRING|"0"
attcount=STRING|"0"
loadfile=STRING|"0"
nodenamevar=STRING|"nodeName"
path=STRING|"*"
savechildcount=STRING|"0"
savedepth=STRING|"0"
savenodename=STRING|"1"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
sortmode=STRING|"0"
textvar=STRING|"NodeText"
withsubnodes=STRING|"1"
xml00000000=STRING|"<root xmlns:bmecat=""http://localhost"">"
xml00000001=STRING|"{xml}"
xml00000002=STRING|"</root>"
xmlcount=STRING|"3"
message=STRING|"{nodeName} - {NodeText}"
Post
by Oleg » Tue Nov 12, 2024 12:25 pm
Another way:
You can remove the
namespace from this part of XML to process all necessary nodes
Look at the second example:
ExternalName=STRING|"Task19"
ID=INTEGER|2055521320
Name=STRING|"get nodes - 2"
StepPause=INTEGER|0
Name=STRING|"STR Replace"
mode=STRING|"0"
source=STRING|"{xml}"
substring=STRING|"bmecat:"
variable=STRING|"xml"
ActionID=STRING|"A_XML_GETNODE"
Name=STRING|"XML Get Single Node"
_rt_variables_produced=STRING|"NodeText"
attcount=STRING|"0"
foundresult=STRING|"1"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"*\NAME2"
raiseerror=STRING|"1"
savenodename=STRING|"0"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
xml00000000=STRING|"{xml}"
xmlcount=STRING|"1"
message=STRING|"{NodeText}"
attcount=STRING|"0"
loadfile=STRING|"0"
path=STRING|"\ADDRESS\*"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
sortmode=STRING|"0"
xmlcount=STRING|"2"
message=STRING|"{nodeName} : {NodeText}"
gremlin
Post
by gremlin » Tue Nov 12, 2024 3:20 pm
Thank you,
I would like to read the individual values into variables in order to create a CSV from them.
I can't read any values here:
Post
by Oleg » Tue Nov 12, 2024 3:31 pm
These nodes have no attributes
You must read node values (node text)
Also I don't see the node with name NAME
Only NAME2 and NAME3
gremlin
Post
by gremlin » Tue Nov 12, 2024 4:15 pm
OK, thank you
