Error while loading DelZip192x64.dll
sarnusch
Post by sarnusch »
I am getting the following error while zipping EDIFACT-files:
Screenshot 2024-10-31 135516.png (16.67 KiB) Viewed 71328 times
The Task is:
CatID=INTEGER|1199727700
ExternalName=STRING|"Task2"
ID=INTEGER|591117214
Name=STRING|"EDIFACT-Dateien in ZIP-Archiv packen"
StepPause=INTEGER|0
Name=STRING|"Set variable ""PATH"" with value ""\\SOURCE"""
_rt_variables_produced=STRING|"PATH"
varname=STRING|"PATH"
varvalue=STRING|"\\SOURCE"
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"FILENAME,FILENAMETIME"
createmode=STRING|"4"
createormodified=STRING|"1"
date1=STRING|"20241031"
date2=STRING|"20241031"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"{PATH}*.txt"
OlderMonths=STRING|"6"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"1"
timevar=STRING|"FILENAMETIME"
ActionID=STRING|"A_ZIP_PACK"
Name=STRING|"Zip Pack Files"
action=STRING|"3"
coment0=STRING|"{DateTime}, {DayOfWeek}"
coment1=STRING|"This zip-archive created by RoboTask"
comentcount=STRING|"2"
compreslevel=STRING|"1"
destfile=STRING|"DESTINATION\test_{MonthName({FILENAMETIME})}_{YEAR({FILENAMETIME})}.zip"
dosformat=STRING|"0"
file0=STRING|"{FILENAME}"
includeemptydirs=STRING|"0"
includesubfolders=STRING|"0"
incsysandhidden=STRING|"0"
junkdirnames=STRING|"0"
password=STRING|"2488925458254552622424944"
message=STRING|"{FILENAME} - {FILENAMETIME} - {MonthName({FILENAMETIME})}_{YEAR({FILENAMETIME})}"
Many files are zipped but then the process ends with the error.
After that the Task will not work again.
After restarting RoboTask the Task starts again but the same error occurs.
What can cause this error?
Re: Error while loading DelZip192x64.dll
I need to see the complete log of the task.
Also I recommend you to use MonthNo instead of MonthName
You can get a problem with non-ascii symbols
Another one question: How many files do you want to pack?
sarnusch
Post by sarnusch »
I changed from MonthName to MonthNo but I still get the same error.
The folder contains 1639 files.
The error occurs after 1016 files.
I have sent the log via mail.
Edit: each file has a maximum size of 2 KB.
