Add days to date (variable)
sarnusch
Post by sarnusch »
I am using a python script to add days to a date that comes from a variable.
Calling the python script in a 'Dataset Loop' slows the execution of the task down.
Is there a way to handle the calculation without a script?
from robotask import *
from datetime import datetime
from datetime import timedelta
rt = RoboTask()
new_date_format = "%Y%m%d"
dtm44 = rt.expand_text('{FIELDVALUE(5)}')
deliverytime = int(rt.expand_text('{FIELDVALUE(6)}'))
year = dtm44[6:10]
month = dtm44[3:5]
day = dtm44[:2]
given_date_string = year + "-" + month + "-" + day
#conversion from string to datetime object
given_date = datetime.strptime(given_date_string,"%Y-%m-%d")
#calculating new date
new_date = given_date + timedelta(days=deliverytime)
new_date = new_date.strftime(new_date_format)
rt.set_user_var('DTM17DATE', str(new_date))
Re: Add days to date (variable)
Yes of course.
The example with VB evaluate action. By the way VB script is very fast in Windows™.
ExternalName=STRING|"Task1533"
ID=INTEGER|84118130
Name=STRING|"add days to date (VB evaluate)"
StepPause=INTEGER|0
Name=STRING|"Set variable ""dt1"" with value ""{Date}"""
_rt_variables_produced=STRING|"dt1"
varname=STRING|"dt1"
varvalue=STRING|"{Date}"
Name=STRING|"Set variable ""DeliveryDays"" with value ""5"""
_rt_variables_produced=STRING|"DeliveryDays"
varname=STRING|"DeliveryDays"
varvalue=STRING|"5"
Name=STRING|"VB Evaluate"
_rt_variables_produced=STRING|"dt2"
expression=STRING|"dateadd(""d"",{DeliveryDays},cdate(""{dt1}""))"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"dt2"
Name=STRING|"Show results"
msg0=STRING|"begin date = {dt1}"
msg1=STRING|"delivery days = {DeliveryDays}"
msg2=STRING|"new date = {dt2}"
msgcount=STRING|"3"
Next example uses only internal actions. It uses Value format action and Add system variable
ExternalName=STRING|"Task1534"
ID=INTEGER|-1919157832
Name=STRING|"add days to date (internal actions)"
StepPause=INTEGER|0
varvalue=STRING|"5"
ActionID=STRING|"A_VALUEFORMAT"
Name=STRING|"Value format (Systemtime->DateAsNumber)"
_rt_variables_produced=STRING|"FormatResult"
format=STRING|"Systemtime"
fromvalue=STRING|"{dt1}"
group=STRING|"Time"
resultvar=STRING|"FormatResult"
reverse=STRING|"1"
value=STRING|"DateAsNumber"
Name=STRING|"Value format (DateAsNumber->Systemtime)"
fromvalue=STRING|"{Add({FormatResult},{DeliveryDays})}"
group=STRING|"Time"
resultvar=STRING|"dt2"
reverse=STRING|"0"
msgcount=STRING|"3"
Try these examples
sarnusch
Post by sarnusch »
the second example works fine for me. Thank you very much!
sarnusch
Post by sarnusch »
I want to ask if it is possible to modify the task (with internal actions or VB script) so that only working days are added?
Hm-m...
Working days are not just from Monday to Friday
There are also public holidays. And the holidays are different in different countries.
sarnusch
Post by sarnusch »
For my example, it is sufficient that the working days are Monday to Friday.
I tried to implement the following VB script in RoboTask but I could not get it to work with the "VB Script" and "VB Evaluate":
Dim startdate As Date
Dim enddate As Date
Dim daysToAdd As integer
startDate = "01-10-2025"
daysToAdd = 10
enddate = startDate
While daysToAdd > 0
	enddate = DateAdd("d", 1, enddate)
	If enddate.DayOfWeek() > 0 and enddate.DayOfWeek() < 6 Then
		daysToAdd = daysToAdd - 1
	End If
End While
System.Console.WriteLine(enddate)
How can I pass my date in a variable to the script and get a result from the script?
An adapted script is given below
function AddWorkingDays(StartDate, WorkingDays)
  StartDate = cdate(StartDate)
  enddate = startDate
  while WorkingDays > 0
    wd = Weekday(enddate)
    '1 = sunday
    '7 = saturday
    If (wd > 1) and (wd < 7) Then
		  WorkingDays = WorkingDays - 1
    end if
  wend
  AddWorkingDays = enddate
end Function
Also look at the my example below
CatID=INTEGER|45174721
ExternalName=STRING|"Task1468"
ID=INTEGER|-523817162
Name=STRING|"Add working days only"
StepPause=INTEGER|0
Name=STRING|"Set variable ""startDate"" with value ""{Date}"""
_rt_variables_produced=STRING|"startDate"
varname=STRING|"startDate"
Name=STRING|"Set variable ""WorkingDays"" with value ""11"""
_rt_variables_produced=STRING|"WorkingDays"
varname=STRING|"WorkingDays"
varvalue=STRING|"11"
_rt_variables_produced=STRING|"NewDate"
expression=STRING|"AddWorkingDays(""{StartDate}"",{WorkingDays})"
line00000000=STRING|"function AddWorkingDays(StartDate, WorkingDays)"
line00000001=STRING|"  StartDate = cdate(StartDate)"
line00000002=STRING|"  enddate = startDate"
line00000003=STRING|"  while WorkingDays > 0"
line00000004=STRING|"    enddate = DateAdd(""d"", 1, enddate)"
line00000005=STRING|"    wd = Weekday(enddate)"
line00000006=STRING|"    '1 = sunday"
line00000007=STRING|"    '7 = saturday"
line00000008=STRING|"    If (wd > 1) and (wd < 7) Then"
line00000009=STRING|"		  WorkingDays = WorkingDays - 1"
line0000000A=STRING|"    end if"
line0000000B=STRING|"  wend"
line0000000C=STRING|"  AddWorkingDays = enddate"
line0000000D=STRING|"end Function"
line0000000F=STRING|"'d = AddWorkingDays(""10.01.2025"", 2)"
line00000010=STRING|"'LogMessage(d)"
linecount=STRING|"17"
variable=STRING|"NewDate"
message=STRING|"start = {startDate}{eol}New date = {NewDate}{eol}Woking days ={WorkingDays}"
sarnusch
Post by sarnusch »
Good morning,
thank you very much!
I will implement it into my task.
