Between certain time period
Hey Oleg,
Due to X-mas we want to have a certain action to be executed.
Between and including 06-12-Year and 05-01-Year (dd-mm-yyyy) this action should take place. I've tried to solve it with a "If" {Date} => 6-12-{Year} AND {Date} <= 5-1-[Year} but that was too simple, it didn't work. Do you have any thoughts what can be the best solution?
I've used Compare Value as Date / Time.
felipe
Re: Between certain time period
Post by felipe »
CatID=INTEGER|1864609949
ExternalName=STRING|"Task169"
ID=INTEGER|-282037269
Name=STRING|"check fromDate toDate"
StepPause=INTEGER|0
ToLog=INTEGER|1
Name=STRING|"checkDate"
_rt_variables_produced=STRING|"checkDate"
varname=STRING|"checkDate"
varvalue=STRING|"31/12/2024"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"false"
ActionID=STRING|"A_VALUEFORMAT"
Name=STRING|"convert_checkDate"
_rt_variables_produced=STRING|"value_checkDate"
format=STRING|"Systemtime"
fromvalue=STRING|"{checkDate}"
group=STRING|"Time"
resultvar=STRING|"value_checkDate"
reverse=STRING|"1"
value=STRING|"DateAsNumber"
Name=STRING|"fromDate"
_rt_variables_produced=STRING|"fromDate"
varname=STRING|"fromDate"
varvalue=STRING|"06/12/2024"
Name=STRING|"convert_fromDate"
_rt_variables_produced=STRING|"value_fromDate"
fromvalue=STRING|"{fromDate}"
group=STRING|"Time"
resultvar=STRING|"value_fromDate"
reverse=STRING|"1"
Name=STRING|"toDate"
_rt_variables_produced=STRING|"toDate"
varname=STRING|"toDate"
varvalue=STRING|"30/12/2024"
Name=STRING|"convert_toDate"
_rt_variables_produced=STRING|"value_toDate"
fromvalue=STRING|"{toDate}"
group=STRING|"Time"
resultvar=STRING|"value_toDate"
reverse=STRING|"1"
message=STRING|"check- {checkDate} = ({value_checkDate})  |  from- {fromDate} = ({value_fromDate})  |  to- {toDate} = ({value_toDate})"
case#1=STRING|"0"
count=STRING|"2"
operator=STRING|"2"
operator#1=STRING|"4"
type=STRING|"1"
type#1=STRING|"1"
value1=STRING|"{value_checkDate}"
value1#1=STRING|"{value_checkDate}"
value2=STRING|"{value_fromDate}"
value2#1=STRING|"{value_toDate}"
message=STRING|"true"
Wow. OK, I'm surprised with this solution ;) I've never expected this to be honest, seems more complicated than I thought. Nevertheless, it works. So, thanks!
Note that the year changes when you move to a new year.
You should compare the current date this way:
((CurrentDate >= Year-12-06) and  (CurrentDate <= Year-12-31)) OR ((CurrentDate >= Year-01-01) and  (CurrentDate <= Year-01-06))
Look at my example
ExternalName=STRING|"Task1515"
ID=INTEGER|2095948155
Name=STRING|"X-mas dates"
StepPause=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Set variable ""ControlDate"" with value ""{Date}"""
_rt_variables_produced=STRING|"ControlDate"
varname=STRING|"ControlDate"
varvalue=STRING|"{Date}"
Name=STRING|"If Then // check XMasDate"
value1=STRING|"{XMasDate}"
Name=STRING|"Show ""Yes!!!"""
[Actions\Action12\Params]
msg0=STRING|"Yes!!!"
msg1=STRING|"Today is X-mas day!"
msgcount=STRING|"2"
Name=STRING|"Else"
[Actions\Action14]
Name=STRING|"Show ""Today is not X-mas day..."""
[Actions\Action14\Params]
icon=STRING|"0"
msg0=STRING|"Today is not X-mas day..."
[Actions\Action15]
Name=STRING|"Set variable ""Date1"" with value ""{FormatToDateTime({Year}-12-06,yyyy-mm-dd)}"""
_rt_variables_produced=STRING|"Date1"
varname=STRING|"Date1"
varvalue=STRING|"{FormatToDateTime({Year}-12-06,yyyy-mm-dd)}"
Name=STRING|"Set variable ""Date2"" with value ""{FormatToDateTime({Year}-01-05,yyyy-mm-dd)}"""
_rt_variables_produced=STRING|"Date2"
varname=STRING|"Date2"
varvalue=STRING|"{FormatToDateTime({Year}-01-05,yyyy-mm-dd)}"
Name=STRING|"Set variable ""XMasDate"" with value ""false"""
_rt_variables_produced=STRING|"XMasDate"
varname=STRING|"XMasDate"
varvalue=STRING|"false"
Name=STRING|"If Then // Year-12-06 <= date <= Year-12-31"
case#1=STRING|"0"
count=STRING|"2"
operator=STRING|"2"
type=STRING|"2"
type#1=STRING|"2"
value1=STRING|"{ControlDate}"
value1#1=STRING|"{ControlDate}"
value2=STRING|"{Date1}"
value2#1=STRING|"{FormatToDateTime({year}-12-31,yyyy-mm-dd)}"
Name=STRING|"Set variable ""XMasDate"" with value ""true"""
varvalue=STRING|"true"
Name=STRING|"If Then // Year-01-01 <= date <= Year-01-05"
case#1=STRING|"0"
count=STRING|"2"
operator=STRING|"2"
type=STRING|"2"
type#1=STRING|"2"
value2=STRING|"{FormatToDateTime({year}-01-01,yyyy-mm-dd)}"
value2#1=STRING|"{Date2}"
[\Comment]
s1=Detect than date between Year-12-06 and NextYear-01-05
Great, thanks! This works excellent.
