Result of sql query in mail body
sarnusch
Post by sarnusch »
I am searching for a method to send sql query results via mail to a user. In my example I want to inform a user about new products.
What I need is that the fieldnames and filedvalues are displayed in the mail body as a table.
At the moment I use 'Dataset Loop' and create a CSV file that is attached to the mail.
But in my opinion it is too much effort for a few lines that also can be displayed directly in the mail body.
With other actions like 'SQL Query to CSV file' I can just get the field values and not get the field names.
Does a functionality like this exist?
Re: Result of sql query in mail body
You need to create some HTML text from your data and send this text as HTML email
look at my example
My test table contains 4 fields. So the table has 4 columns
ExternalName=STRING|"Task1474"
ID=INTEGER|-1526922036
Name=STRING|"Send SQL data as table"
StepPause=INTEGER|0
Name=STRING|"Set variable ""filename"" with value ""{TempDir}\table.html"""
_rt_variables_produced=STRING|"filename"
varname=STRING|"filename"
varvalue=STRING|"{TempDir}\table.html"
Name=STRING|"Create text file {filename}"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{filename}"
line0=STRING|"<html>"
line1=STRING|"<body>"
line2=STRING|"<table style=""width: 100%"">"
line3=STRING|"<tr>"
line4=STRING|"<td style=""width: 25%"">Field 1</td>"
line5=STRING|"<td style=""width: 25%"">Field 2</td>"
line6=STRING|"<td style=""width: 25%"">Field 3</td>"
line7=STRING|"<td style=""width: 25%"">Field 4</td>"
line8=STRING|"</tr>"
linecount=STRING|"9"
suppress=STRING|"0"
withoutprefix=STRING|"1"
Name=STRING|"Dataset Loop"
_rt_variables_produced=STRING|"data,fld"
commatext=STRING|"0"
connectionstring=STRING|"Provider=MSDASQL.1;Persist Security Info=False;Extended Properties=""DATABASE=testdata;DB=testdata;DSN=testdata;NO_CATALOG=;NO_SCHEMA=1;PORT=3306;PREFETCH=;SERVER=127.0.0.1;"""
override=STRING|"1"
paramcount=STRING|"0"
password=STRING|"3516836025370673578335260"
sql=STRING|"""select * from datatable  where <some_condition>"""
timeout=STRING|"60"
userid=STRING|"username"
var1=STRING|"fld"
var2=STRING|"data"
withmemo=STRING|"0"
encode=STRING|"0"
fileexists=STRING|"1"
line0=STRING|"<tr>"
line1=STRING|"<td style=""width: 25%"">{data(0)}</td>"
line2=STRING|"<td style=""width: 25%"">{data(1)}</td>"
line3=STRING|"<td style=""width: 25%"">{data(2)}</td>"
line4=STRING|"<td style=""width: 25%"">{data(3)}</td>"
line5=STRING|"</tr>"
linecount=STRING|"6"
suppress=STRING|"0"
encode=STRING|"0"
line0=STRING|"</table style=""width: 100%"">"
line1=STRING|"</body>"
line2=STRING|"</html>"
linecount=STRING|"3"
suppress=STRING|"0"
Name=STRING|"Run ""{filename} """
ifnonzero=STRING|"0"
program=STRING|"{filename}"
runas=STRING|"0"
wait=STRING|"0"
Enabled=INTEGER|0
Name=STRING|"SMTP Send Email"
attachcount=STRING|"0"
auth=STRING|"0"
charset=STRING|"utf-8"
from=STRING|"user@host.com"
host=STRING|"Myhost.com"
html=STRING|"0"
msg0=STRING|"{TextFile({filename})}"
password=STRING|"2488925201249412596972562"
port=STRING|"25"
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"2"
subject=STRING|"New data"
tlsmode=STRING|"0"
tlsver=STRING|"2"
to=STRING|"target@host.com"
xmailer=STRING|"RoboTask"
But I think that sending CSV file is not bad Idea
use the option "Use Field Names" (see screenshot)
SQL Query to CSV File.png (23.61 KiB) Viewed 60622 times
sarnusch
Post by sarnusch »
Good morning,
thanks for your quick reply and the great help.
I just tested it and it works fine.
