JavaScript - assign result of fn to variable robotakst
felipe
Post by felipe »
function fn(a, b) {
return a + " " + b;
var result = fn("hello", "world");
RoboTaskApp.AddUserVariable(RoboTaskApp.ExpandText(VariableNameResult, result);
could help format the synthase
tks
Re: JavaScript - assign result of fn to variable robotakst
Look at my example below
ExternalName=STRING|"Task1465"
ID=INTEGER|2102349058
Name=STRING|"JS Script..."
StepPause=INTEGER|0
ActionID=STRING|"A_SCRIPT_JSSCRIPT"
Name=STRING|"JS Script"
expandvars=STRING|"0"
line00000000=STRING|"function myfn(a, b)"
line00000001=STRING|"  {"
line00000002=STRING|"  return a + "" "" + b;"
line00000003=STRING|"  }"
line00000005=STRING|"VariableNameResult = ""ResVar"";"
line00000006=STRING|"result = myfn(""hello"", ""world"");"
line00000008=STRING|"//logmessage(result);"
line00000009=STRING|"RoboTaskApp().SetUserVariable(VariableNameResult, result);"
linecount=STRING|"11"
savescript=STRING|"0"
message=STRING|"{ResVar}"
The script is
function myfn(a, b)
  return a + " " + b;
VariableNameResult = "ResVar";
result = myfn("hello", "world");
felipe
Post by felipe »
I'd like to return to this post so I don't have to open another one, in this variable assignment context
in this context the variable is always applying globally, I'd like it to be only within the task
I've already declared it at the beginning of the task with the same name as the variable assigned in the function, the function applies globally, this interferes with another task with the same variable name
Try to use variable name like this: "local@ResVar"
Also you can create local variable with necessary name
Look at my example below. I have global variable MyVar. By the script set value to local variable MyVar
CatID=INTEGER|307868550
ExternalName=STRING|"Task1583"
ID=INTEGER|-1222492109
Name=STRING|"Global and local variables"
StepPause=INTEGER|0
Enabled=INTEGER|0
Name=STRING|"Set variable ""local@myvar"" with value ""Local var"""
_rt_variables_produced=STRING|"local@myvar"
varname=STRING|"local@myvar"
varvalue=STRING|"Local var"
line00000005=STRING|"VariableNameResult = ""local@MyVar"";"
line00000008=STRING|"RoboTaskApp().SetUserVariable(VariableNameResult, result);"
linecount=STRING|"9"
Name=STRING|"Show ""{global@myvar}"""
msg0=STRING|"{global@myvar}"
msg1=STRING|"{local@myvar}"
msgcount=STRING|"2"
Also read about prefixes here: https://robotask.com/help/index.html?pr ... iables.htm
felipe
Post by felipe »
[pyhton]
from robotask import *
a = 23.5
b = 37.8
c = a + b
rt = RoboTask()
rt.set_user_var('local@MyVariable', str(c))
if it is correct, it is not working, it is not applying the variable
Unfortunately Python Script and Node.JS script actions can set only local variables now and does not process prefixes.
We'll fix this problem in next release.
