How to launch a task with a delay after the system boots up
skrak
Post by skrak »
Hi there, I just joined.
I would like a task to begin once the system has started, perhaps after five minutes. The task should also be able to be started with a hotkey.
How do I make this? Regards!
Re: How to launch a task with a delay after the system boots up
You need 2 tasks
create Main task with HotKey trigger
Create another task with two steps: On the Triggers tab in the Task Editor, enable the "Run task when RoboTask starts" check box
